Rear headliner trim screw holes are wallowed out - looking for ideas to fix
Discussion in 'Interior Restoration' started by 76_TypeLT, Feb 9, 2017.
  1. jthomas
    1,493
    54
    Dec 5, 2007
    NorthCentral PA
    I assume your talking about the metal behind the trim piece right? If so, I get my mig welder out and spark an arc inside the hole once or twice. Then I run a fresh machine screw through it to get it ready for the regular screw. Works well and solves the problem for good. It hardens the metal around the hole and bites good.
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    jthomas likes this.
  3. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    This would be the ideal solution but I have too much stuff installed at this point unfortunately. I guess I could lay down a bunch of towels and blankets for the sparks and slag.
  4. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
  5. garyandcindy
    garyandcindy Veteran Member
    1,579
    Oct 20, 2004
    cumming,ga-usa
    Like posted above.Cut a piece of thin gauge metal and bend it in a v shape.Slide into slot and pitch or glue the v in place.It will make the slot smaller and make your screws bite.Be careful not to overtighten.I've done it.It works.
  6. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    that's a clever idea too, thanks
  7. hogg
    hogg Veteran Member
    3,126
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    pack hole with steel wool, mabe some glue from a hot glue cgun, don't take much
  8. bfendick
    bfendick Veteran Member
    141
    Dec 3, 2006
    Vernon, BC
    You can put a flat toothpick in the hole when you start the screw and then break it of once the screw is in, the wood will fill the gap and hold the screw in place until you remove it again.
  9. Zspoiler
    Zspoiler Veteran Member
    There are usually something in the "Help Section" in most Auto Parts stores.
  10. Fbird
    2,432
    99
    Feb 12, 2011
    atlanta, ga
    can you get to the back side of the hole... if so you can simply use a pair of vise grips and squeeze the material at the hole.... it will make the hole smaller.... do this all time on sheetmetal screw holes that get wallered out.
