Rear end modification parts DSE
Discussion in 'Swap Meet Section' started by dave@ztech, Jun 17, 2019.
  1. dave@ztech
    3,078
    592
    Mar 27, 2016
    NY
    So I got a few parts that I may not use, and felt that someone might, you have to know what DSE sells to perhaps understand what I have, DSE offset shackles for the rear and the DSE spring pocket? for the front , DSE shocks for tubbed rear, the upper shock mount bar, and modified Caltracks for the DSE tubbed rear, these would be a little over $1,000 , looking for $600 OBO, let me know if you have questions . less then 1000 miles on parts
    Thanks
  2. Tpichevy
    Tpichevy Veteran Member
    489
    16
    Jun 21, 2016
    Boise id
    Pm sent
  3. camaro71/holland
    1,150
    58
    Aug 27, 2003
    The Netherlands
    If it doesn't work out and you're willing to split, I'll be interested in the front and rear spring mounting setup.
    dave@ztech likes this.
  4. badazz81z28
    16,145
    375
    Las Vegas, NV
    You’ll need it all if you move the springs inboard
    Or else you won’t be able to mount shocks
  5. dave@ztech
    3,078
    592
    Mar 27, 2016
    NY
    Or you will need some fab skills, they sell the upper spring mounts as a separate item on DSE site, and the Caltracs have the lower spring mount built onto it , you can however buy the lower spring mounts , also from DSE with the mounting point,
  6. badazz81z28
    16,145
    375
    Las Vegas, NV
    ^ weird on what you can buy separate and what you can’t
  7. dave@ztech
    3,078
    592
    Mar 27, 2016
    NY
    Yes it is , I can get anything I want however, have a guy, HAA HA
    badazz81z28 likes this.
  8. camaro71/holland
    1,150
    58
    Aug 27, 2003
    The Netherlands
    Plan would be to move the stuff inboard, cut the existing upper mounts and reweld in the new position, use caltrak plates for lower mounting, then weld a bar between the frames for the shocks. Dunno, never done this before so I think I can do it....:crazy:
  9. dave@ztech
    3,078
    592
    Mar 27, 2016
    NY
    I have the upper shock mount bar, however , it was cut ? removed to setup the 4 link system , I also have a couple of plates that are common to the two, 4 link, and leaf spring install , you can look at and down load the install instructions from DSE site , just go to what setup you are looking at , and you will see the download instructions , install , what you would be missing to do the mini tub install is that complete kit , $400 something , and the leaf springs , , the complete kits sells for $2200 , so if you have the springs , and good bushings , then you know what you will need to complete, and some fab skills , pretty strait forward, the caltracks are heavy and so if the upper shock bar , so I don't know if you would want that shipping to the Netherlands , the billet offset and the upper leaf things are not so bad , and will fit in a small box. well 10x 10 box
