real 70 z-28 or not
Discussion in '1970 - 1973 Specific' started by creeker70, Jun 4, 2013.
  1. bkmont
    bkmont Veteran Member
    985
    22
    Nov 14, 2010
    Pensacola, Florida
    My frame has 51170N1 stamped on it.
  2. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    609
    16
    Aug 18, 2011
    Upstate New York
    V0707CTC is the engine manufacture stamp from the engine plant (V = Flint, Mich.) Posting a picture of this would be helpful for comparison as well.
    Your VIN sequence should be 10Nxxxxxx, and should be above the oil filter, not on the deck. The engine block casting is there, and you should be able to see it with engine in the car. Behind the passenger deck on top of the block IIRC. The 3970010 is on the opposite side.
    This is not a stamp, but cast in when the block was poured at the foundry.
    The transmission tag should be easy to see with the car up in the air.:bowtie:
  3. 2ndGenCrazy
    609
    16
    Aug 18, 2011
    Upstate New York
    Transmission ID tag example
  4. deszs
    deszs Member
    46
    Feb 7, 2007
    Byron, GA
    On the 1970 Z28 I once owned, the VIN was stamped on the turbo 400. I found it on a narrow casting surface right behind the location where they stamped the block above the oil filter. Seems like the same person stamped the block and the transmission only seconds apart.
  5. creeker70
    creeker70 Member
    78
    May 31, 2013
    b.c. canada
    70 z-28 pics daytona yellow project
    if you go to photo gallery creeker 70 there is a few pics of my z-28:p :bowtie: :bowtie: :bowtie: :bowtie: :bowtie: :bowtie: :bowtie:
  6. Budz
    2,925
    36
    Mar 17, 2002
    Ashburn, Va USA
    From those few pics....looks like you have a keeper, creeker ;-) :bowtie:
  7. creeker70
    creeker70 Member
    78
    May 31, 2013
    b.c. canada
    number on frame rail daytona yellow z-28 project
    the number on my frame rail is :) 5127on1
  8. bkmont
    985
    22
    Nov 14, 2010
    Pensacola, Florida
    Our frames were made pretty close together:bowtie: .
    My 51170N1 for my VO629CTC
    Your 51270N1 for your V0707CTC
    :cool:
  9. al8apex
    al8apex Veteran Member
    3,916
    Mar 11, 2005
    scottsdale, az
    where did you find this breakdown of production numbers?
    AFAIK there is no way to determine how many 70 Z28's are automatics vs 4 speed and no way to determine how many were M22, etc
  10. creeker70
    creeker70 Member
    78
    May 31, 2013
    b.c. canada
    daytona yellow z project
    also the numbers for the date code on the differential is e260 which means may 26 1970:bowtie: :bowtie: :bowtie: :bowtie:
