Rattling noise - trunk lid?
Discussion in '1970 - 1973 Specific' started by Tequila, Jul 26, 2017.
  1. Tequila
    Tequila Veteran Member
    110
    Oct 25, 2013
    Seattle
    I was wondering if you have any suggestions on how to isolate the a loud vibrating sound from the rear of the car as my 72 Camaro is idling. Also on low speeds I hear the same sound. Once I start picking up speed noise goes away..
    I just replaced out the differential, leaf springs, and shocks. Everything appears to be tight and nothing loose. I did notice some rattling noise as I tap on my trunk lid. I was wondering if there are any rubber pieces to cushion between the top and bottom sheet metal on the trunk lid? I have the mufflers added but not the tail pipe yet. I know it is a bit loud from not having the tail pipe section yet, but nothing loose with the exhaust pipe leading up to the muffler.
    Thank you.
  2. twozs
    twozs Veteran Member
    8,779
    159
    Aug 5, 1999
    hopewell jct ny
  3. wiseryder
    2,028
    33
    Sep 11, 2004
    belding,mi USA
  4. 71flh
    71flh Veteran Member
    942
    20
    Jun 1, 2010
    DFW
    Lol! Or take the deck lid off, or put something in the pinch points.
    Maybe sound deadening on the deck lid and behind the seat?
    The rear of my car makes odd noises as well, so watching.
  5. Tequila
    110
    Oct 25, 2013
    Seattle
    Thanks twozs. I needed a laugh.
    71flh, I will try your suggestions. Also, noticed that I am missing the rubber bumper for the trunk lid.
  6. paintman65
    paintman65 Veteran Member
    180
    Jan 8, 2012
    Brenham TX
    I had a similar noise that sounded like it was coming from the back of the car and was driving me crazy. Turns out it was the parking brake cable rubbing on the exhaust. Maybe try opening the decklid with the car running and see if the noise changes or goes away.
  7. jimrr
    jimrr Veteran Member
    1,236
    276
    Jun 12, 2016
    sarasota
    shut your wife in the trunk and then drive around town...........:)
    joselk1 likes this.
  8. bucco47
    bucco47 Veteran Member
    147
    Oct 30, 2008
    Tampa, FL
    could be the torsion rods/trunk springs if the rubber insulator has deteriorated
  9. xten
    xten Veteran Member
    1,865
    884
    Sep 24, 2014
    Pittsburgh, Pa.
    Mine was the license plate mounting plate (with the hinge) when the sub hit.
  10. joselk1
    joselk1 Veteran Member
    204
    11
    Jul 24, 2014
    Waterford, MI
    My desk lid makes the same noise...I can tap the deck lid and recreate the sound. It’s almost as if the 2peices of sheet metal are vibrating against each other. I thought about cramming a couple of rubber bumpers in between them if I can.
