Rarity! True or Perceived
Discussion in '1974 Specific' started by zfool, Jan 6, 2015.
HEI T-!0 vs. Points Muncie
  1. More Value For HEI T-10
    3 vote(s)
    20.0%
  2. No Difference
    12 vote(s)
    80.0%
  1. CamaroNmotion
    CamaroNmotion Veteran Member
    252
    Jan 8, 2006
    Buffalo, NY
    I am original owner of a special ordered 74 Type LTZ28 which still has the original Muncie M20 wide ratio transmission. I also have the posi 3.73:1 rear end.
  2. zfool
    zfool Veteran Member
    502
    May 19, 2014
    Rochester, MN
    Its in the 74 assembly manual as well for both 3.73 and 3.42
  3. twozs
    twozs Veteran Member
    8,512
    91
    Aug 5, 1999
    hopewell jct ny
    if you look at the 14 inch tire M20 that was the wide ratio saginaw 4 speed ( cast iron ) . gm called both wide ratio transmissions , saginaw and muncie an M20 . it depended on the car it was ordered on .
  4. CamaroNmotion
    252
    Jan 8, 2006
    Buffalo, NY
    Correct. The letter "M" is NOT to be confused with and meant to mean Muncie. M20,M21 are just codes used by GM (generally meant M20-for wide ratio & M21- for close ratio transmission. Muncie trans ALL had the aluminum cases. Saginaw had cast iron cases.
  5. twozs
    8,512
    91
    Aug 5, 1999
    hopewell jct ny
    Good ! I though the 15 years I've been coming to this web site was just wasted time ...
