Railway sleepers put to good usage...!
Discussion in 'Tips 'n' Tricks Topic' started by The Seer, Jan 7, 2016.
  1. The Seer
    The Seer Veteran Member
    489
    Nov 1, 2014
    Essex England
    Got hold of some redundant railway sleepers a few months back. Sliced em' up for a two tier system...
    Damn site more stable and solid than those silly D.I.Y. metal ramps...
  2. The Seer
    489
    Nov 1, 2014
    Essex England
    Good clearance too...
  3. harbone66
    3,392
    222
    Feb 15, 2011
    Central Illinois
    Those are nice!!
  4. Twisted_Metal
    25,370
    322
    We call those "Railroad Ties". ;)
    They're solid!
    They will last a hundred years for car ramps! :D
  5. The Seer
    489
    Nov 1, 2014
    Essex England
    Thanks :) I've never felt 100% about axle stands, they're good but these give me more confidence. I may make some for the rear too.
  6. The Seer
    489
    Nov 1, 2014
    Essex England
    Railroad Ties eh, do you gentlemen over in the states use these as well for working on your vehicles? Hopefully they will last, they're full of creosote as you probably know.
  7. grzewnicki
    Yours appear to be about 1/2 or 2/3 the thickness a R/R tie would be here in the states, they are usually 8 x 8 inches (20 x 20 cm). Pretty dang heavy too, yup soaked with creosote here too. Good idea but I'll stick with my Rhino ramps that I can throw in the attic when I'm done with them.
  8. The Seer
    489
    Nov 1, 2014
    Essex England
    I could throw mine in the loft too, if had a better physique ;) I think your locomotives are a fair bit heavier than ours over here hence the difference in size. Once I'm done with a job I drag the ramps and store them round the back of the house, thankfully only a short distance.
  9. KEVS79
    KEVS79 Veteran Member
    2,467
    Mar 3, 2008
    GLADSTONE, MO
    Looks nice and solid. You could mount some casters on the ends, then when you move them you could flip them up and roll them on the casters....or use a dolly.
  10. sparkyboy
    sparkyboy Veteran Member
    242
    14
    Feb 4, 2015
    aurora, co
