Question on brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ULTM8Z, Dec 24, 2017.
  1. badazz81z28
    14,554
    149
    Las Vegas, NV
    I had my car on a road course and the drag strip, no complaints at all in the breaking department.
    Does anyone have a picture of the pedals? I believe all of mine only had one hole for the rod.
  2. 74BIBELOT
    74BIBELOT Veteran Member
    Thanks to TC people 54D3A397-C6B2-4427-8CF2-BF6FA96CFD83.jpeg A70C85A1-2C9A-40F4-9E78-206BE645A98F.jpeg 76832C18-FD8F-4DC3-8C91-34AE1A44BF6E.jpeg
  3. 8pack
    2,295
    60
    Aug 29, 2007
    Pittsburgh, PA
    So, now how do you find a disc/disc pedal! Will anyone even know what they have!?
  4. 8pack
    2,295
    60
    Aug 29, 2007
    Pittsburgh, PA
  5. Todd80Z28
    11,004
    55
    Jun 11, 2002
    Northern VA
    Mike- you're worried about pedal travel to get braking force? It almost seems like a manufacturer choice thing- almost all my GM stuff has always had that sort of pedal feel, as do my in-laws Toyota stuff. My Honda/Acura stuff has always had a pedal feel I prefer- tighter/more linear without being touchy.
    The exception was my '81 Z with the aluminum master cylinder had better pedal feel than my '80 (which still has disc/drum with 1LE up front).
    I recall reading about "quick uptake" master cylinders back in the day, I wonder if that would change anything? Perhaps the one you have already is??
    I could be full of sh.. on all of this, of course.:) Limited sample size and all that...
  6. ULTM8Z
    ULTM8Z Veteran Member
    8,520
    127
    May 19, 2000
    Los Angeles
    Todd,
    I still need to call Baer. It could be that my brakes are behaving normally. Probably will call after the new year.
  7. 71RS/SS396
    71RS/SS396 Veteran Member
    2,598
    20
    Aug 26, 2008
    Wake Forest NC
    The 81 master is a step bore/quick takeup.
  8. ULTM8Z
    8,520
    127
    May 19, 2000
    Los Angeles
    For 4 wheel disc?
  9. badazz81z28
    14,554
    149
    Las Vegas, NV
    I wish I knew what you guys are seeing or feeling. Stock camaro pedal 3x and have no clue what issues you are all seeing. My brakes feel and operate with no strange things. I would suggest to the swapper is use an adjustable prop valve and New or Reman booster and MC. Not 45 year old stuff that like has leaks and wear. I again will would suspect the issues are faulty parts and air in the system. Not the pedal.
  10. Zulu28
    Zulu28 Veteran Member
    215
    15
    Dec 19, 2013
    Vancouver, BC
    Hear's another option that I have, this is fourth gen rear disk.
    Check your axle flange, should be the same pattern, what I'm not sure about is axle flange offset, might have to shim the caliper mount, from what I'm reading that's not unusual.
