question for guys with lifts in your shop
Discussion in 'Garages, Workshops & Tools' started by 5spd540, Apr 4, 2014.
  1. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    How tall of a building do I need to build to put a lift in? I am in the process of having the cement done on Monday then I will be putting a building up.
    Thanks for the info in advance
  2. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,020
    Sep 22, 2007
    Blind Bay, B.C.
  3. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    Is that 12ft walls or ceiling height
  4. Happy_Dan
    Happy_Dan Veteran Member
    740
    107
    Sep 13, 2013
    New Boston, NH
    I have 10 ft studs on top of the doubled up base and 2 ft foundation so the ceiling ends up 12ft and a couple of inches. You can get lower lifts, but even with the 12 ft, I have to have the vehicle all the way up to walk under without crouching. I would highly suggest a 12 ft ceili
    Just for some perspective. The car is up pretty high on the lift. The two guys are each a little over 6ft tall. You can see the garage door opener above the car. Hope this helps.
  5. CamaroDoc
    CamaroDoc Veteran Member
    1,886
    53
    Sep 13, 2003
    Skiatook, Okla. 74070
    I just put one up for my boss. He has 14' ceilings and the door clears his GTO with no problem with the lift all the way up. The lift is a Bend-Pak HD-9, 4 post.
  6. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    Yea I don't want to build it any higher than I have to
  7. 57Plymouth
    57Plymouth Veteran Member
    1,078
    Jul 31, 2001
    Blythewood, SC
    I have 12" to the bottom of the trusses.
  8. hogg
    hogg Veteran Member
    3,156
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    when puring the floor make sure it is thick enought where the post will set
  9. Wadd2
    Wadd2 Veteran Member
    243
    Aug 27, 2013
    Shelton, Nebraska
    12' to bottom of trusses minimum is what was required for my Rotary lift. After install the lift is 2" under my truss. Wouldn't go any shorter than 12'
  10. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    Yea already have that part laid out
