Putting car in the air - 4 jackstands
Discussion in 'Tips 'n' Tricks Topic' started by gadrix, Feb 3, 2008.
  1. li0nhart123
    li0nhart123 Veteran Member
    737
    Jan 20, 2008
    British Columbia
    Cripes!!!.....Jeezus.... You have to be kidding!!!...I wouldn't crawl under that. the only real support you have are the jackstands under your rear subframe...those loose blocks and jackstands under your axles do not count.
    Maybe they are already there....I just can't tell from the picture though...If not then you need to add two more jackstands under your front subframe to make that stable. Never trust jackstands placed under flexible suspension components like axles and a - arms. Jackstands are meant to be palced under ridged components.
    Jackstands also like to be level...if your front tires are on the ground and the rear is up on stands, there is a chance that the jackstands can slip as well.
  2. darryl
    darryl Veteran Member
    165
    Jan 22, 2002
    chicago[area]
    for driving up car ramps.i drilled a hole at the bottom of the ramp where the tires rolls up on and got some thick nylon tow rope at tied it thru the hole then cut the rope the length from the ramp at my front tire to bout a foot past the rear tire.did this for both sides.so now when the front tires go up the ramps the back tires are on the rope and the weight of the car holds the ramps from slipping out
  3. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,645
    Jul 31, 2001
    Ft. Lauderdale, FL
    Wow...........I just now noticed that he chocked the rear wheels for safety!!
  4. Keizer
    Keizer BANNED
    7,971
    Jan 17, 2005
    Wa State
    Pussy!
  5. Bigdog
    Bigdog Veteran Member Lifetime Gold Member
    1,223
    Jun 30, 2006
    Lake Jackson, Tx.
    Just make sure you get the correct year models, otherwise they will not line up correctly.
  6. David Hartley
    David Hartley Veteran Member
    515
    Jun 2, 2006
    Glen St. Mary, Fl.
    Is that guy welding right by the fuel tank?:eek:
  7. protour73
    protour73 Veteran Member Lifetime Gold Member
    6,028
    Sep 21, 2006
    West of Chicago
    bwahahahahahahahahaha;)
  8. li0nhart123
    737
    Jan 20, 2008
    British Columbia
    Let me know how it works out...wheeling around in your chair that is...if you are real lucky, maybe your insurance will buy you a 48volt motorized one...ya know....the one you can operate with your tongue..;)
  9. Keizer
    Keizer BANNED
    7,971
    Jan 17, 2005
    Wa State
    Cars back on the ground. Guess I lucked out on that one. :confused:
  10. Marks71BB
    Man, that was a close call wasnt it? :confused: Bwahahaha
