Purpose of an L-88 hood.
Discussion in 'Camaro Questions' started by str8upsuburbz, Jan 25, 2011.
  1. Rich Schmidt
    Rich Schmidt Veteran Member
    4,215
    30
    Mar 27, 2010
    Denville NJ
    Meee too. They are like belly buttons. I put an 81 Z hood on my 73 nose because I just couldnt go the traditional cowl scoop route. I considered cutting my old L-88 hood to raise it,but I am a bit too lazy sometimes,and in all honesty,it gave me 3 more inches of clearance which was more then enough for my bigblock that sits on 1.5" raised mounts(for added oil pan clearance) and has a Victor 454R intake,and 1.5" carb spacer or 1" nitrous plate.
  2. proshine2004
    proshine2004 New Member
    20
    Feb 1, 2010
    cen ca
    anyone have a picture of a taller l88?
  3. muscl car
    mine is a 4" tall "race weight" L88 hood and is tall enough for my sbc with a holley strip dominator "same size as a edelbrock super victor" ,2" tall open spacer ,holley carb and drop base air cleaner with a 5" tall filter
  4. bfmgoalie
    bfmgoalie Veteran Member
  5. frankz
    frankz Veteran Member
    2,068
    Aug 24, 2009
    Illinois
    Chuck,do you happen to have a pic from the driving position---I'm interested in the line of sight with that hood(yeah I need a hood)
  6. Jim Mac
    Jim Mac Veteran Member
    2,196
    Dec 28, 2004
    tucson az USA
    those hoods look just right! back in the day, I grafted a glass one on my camaro. later on picked up a glass L88 hood, and to this day, I dont remember what I did with it. Went a different route when I thought about adding a big block, I grafted the steel cowl induction dome off a SS chevelle to a camaro hood. Ended up putting a 6-71 on the car, so a scoop doesnt work for me. jim
  7. muscl car
    no i don't but can email a pic to you tomorrow if you want
    i do have a pic of the same hood with a grump lump grafted on ...........maybe this might help !! . if you use the bracket of the fuel pressure gauge as reference that is the top of the L88 hood as you can see with the newer pic
  8. MR. FBDY
    MR. FBDY Veteran Member Lifetime Gold Member
    3,907
    May 30, 2001
    hudson, NY
    are those studded BFG drag radials I see on there? :)
  9. frankz
    2,068
    Aug 24, 2009
    Illinois
    That would be great if you could--Thanks Chuck
  10. K5JMP
    I'm 5'7" and I can see the right front corner pretty easily over mine
