pulley fit -power steering pump
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Aug 17, 2017.
  1. Chuck71RS
    1,011
    24
    Nov 24, 2012
    Houston, Texas
    How can I tell if the pulley needs replacement? Should it slip onto the shaft and key by hand?
    PS pump is still new (installed with the rebuild and hardly any use).
    Original pulley (2 groove for ac) slides on by hand over the shaft and key but have not used it with the new pump
    A chrome pulley was used but wanted something other than chrome. Got rid of it so I don't know the key-way diameter
    Replacement pulley key-way is to small, fits a 7/64" drill bit and the original a 1/8" drill bit
  2. 74BIBELOT
    74BIBELOT Veteran Member
    There are TWO ps pulley types:
    Pressed one and also a double pulley secured with a nut.(threads)
    Last pic from my 74 Camaro(double groove)with AC.
  3. 74BIBELOT
    Sorry, FIRST pic is from my 74 AC Camaro(double groove), you can see part number there.
  4. Chuck71RS
    1,011
    24
    Nov 24, 2012
    Houston, Texas
    All three pulleys (original, chrome and replacement) are double groove for ac
    So, how can I tell if there are any problems with the original pulley fit on the shaft of the new ps pump?
  5. 74BIBELOT
    It depends what type of pump (SHAFT)you are going to use:
    BOLT ON slide by hand and use a NUT. Flat surface where the nut goes.
  6. 74BIBELOT
    PRESSED type pump(SHAFT) use a pulley with a lip to remove or install it with a special "remove/installer" tool.
    Last pic is the installer tool:
