Proper Setup for Relocating the Battery to the Trunk
Discussion in 'Electrical Systems' started by sandiego74, Nov 4, 2017.
  1. muscl car
  2. hoppin5478
    555
    89
    Jul 20, 2015
    Tucson, AZ
    That's a good article, thank you for posting it.
    I generally go with welding cable for a few of the reasons mentioned in the article but also because it seems to be more consistent to the actual advertised gauge of the wire and true copper, not copper clad etc. Unfortunately there is a lot of wire on the market that is overrated (doesn't flow at it's advertised size) and looks correct if you don't know what to look for.
    muscl car likes this.
  3. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,008
    28
    Feb 23, 2009
    San Diego, CA
    This is all really good advice. Thank you, you guys!
  4. Fbird
    2,629
    178
    Feb 12, 2011
    atlanta, ga
    the ford solenoid does add complexity to the system.....yes. Depends on the function of the vehicle. If it's street driven MOST would consider it mandatory to have a "cold" cable to the starter. If its "race only" its considered LIMITED exposure therefore readily acceptable to run a "hot" cable to the starter.
  5. Scott51
    Scott51 Veteran Member
    470
    30
    Jan 2, 2012
    New Zealand
    I looked into both setups and came to the same conclusion - solenoid setup for a car that's primarily street driven, kill switch for one that spends more time at the track.
  6. muscl car
    You mentioned this is for SCCA and to pass their tech inspection , do they require a accessible Batt disconnect switch ???
  7. sandiego74
    1,008
    28
    Feb 23, 2009
    San Diego, CA
    Honestly, I don't know. Does any one know if SCCA requires the external battery disconnect switch?
  8. sandiego74
    1,008
    28
    Feb 23, 2009
    San Diego, CA
  9. sandiego74
    1,008
    28
    Feb 23, 2009
    San Diego, CA
    Also, would it be better to run a Ford solenoid instead of the battery disconnect?
