Project Girasol
Discussion in 'Project Progress' started by Da-bigguy, Jul 29, 2012.
  1. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    991
    11
    Apr 27, 2010
    Verona, ITALY
    Again, thank you guys! Like I said: "always in debt with the big Nasty Family!". Your info helps me a lot. THANKS
  2. Da-bigguy
    3,423
    87
    Jan 19, 2010
    Cypress, TX
    You are very welcome! Glad to be of assistance. Let me know if there is anything else I can do from Houston for you!
  3. 2nd gen man
    2nd gen man Veteran Member
    991
    Nov 28, 2010
    michigan
    looking Good,,
    looks like it will be a lot easier to work on ,,
  4. Da-bigguy
    3,423
    87
    Jan 19, 2010
    Cypress, TX
    Thanks! I will find out if that is the case this weekend when I get back to work out in the garage.
  5. perkalator
    perkalator Veteran Member
    951
    57
    Aug 27, 2014
    kennewick wa
    Well its almost the weekend. Lets see some progress.:)
  6. Da-bigguy
    3,423
    87
    Jan 19, 2010
    Cypress, TX
    There will be tomorrow for sure!
  7. Da-bigguy
    3,423
    87
    Jan 19, 2010
    Cypress, TX
    A little progress on the weekend
    I did manage to get into the garage Sunday and the rotisserie was immediately useful as it allowed me to move the body away from the wall so I could removed the driver's door!
    I also discovered something I'm not sure how I missed before! I took a look at the trim tag to check something and realized it didn't match the VIN!
    If I'm reading the trim tag right, it says my car had a V8 whereas the VIN number says it had a 6 cyl! I'm thinking that trim tag got changed out for some reason. The hidden partial VIN on the firewall matches what is on the full VIN so hopefully there won't be any issues when it comes time to get the vehicle registered.
  8. hot72rod
    That is kind of odd, Not a whole lot of reason to swap tags unless you are trying to fake something.
  9. Da-bigguy
    3,423
    87
    Jan 19, 2010
    Cypress, TX
    I agree, it is odd. However, I'm not planning on restoring it to original but am doing all sorts of modern upgrades so as long as it doesn't cause any problems with doing the registration, I can live with the swapped tag.
  10. giggity
    giggity Veteran Member
    704
    16
    Mar 18, 2013
    Pearland, texas
    you could have a rare GM mistake....might be worth something! ;-)
