Project Girasol
Discussion in 'Project Progress' started by Da-bigguy, Jul 29, 2012.
  1. Da-bigguy
    3,346
    73
    Jan 19, 2010
    Cypress, TX
    Thanks John! I will probably go with the 80cf bottle as Aaron suggested and see how long that lasts me once I start to really dig into the welding repairs I need to do.
  2. Da-bigguy
    3,346
    73
    Jan 19, 2010
    Cypress, TX
    It's almost ready to spin!!!
    I got the body mounted to the rotisserie this weekend!
    I just need to get the bolts tightened that hold the body to the rotisserie and weld some straps to the bottom crossbar as a couple of the bolts that hold the pieces together sheared off, one when I was trying to back it out so one piece of square tubing would slide into the other. I will repair those properly later but for now secure the square tubing with some small welded straps to hold it together.
  3. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    Now you'll be cooking with fire! You can't use it as a storage shelf anymore ;)
  4. Chuck71RS
    1,116
    36
    Nov 24, 2012
    Houston, Texas
    Sure have a lot more room now then your previous garage. Where is the MG?
  5. Da-bigguy
    3,346
    73
    Jan 19, 2010
    Cypress, TX
    That is for sure!!
  6. Da-bigguy
    3,346
    73
    Jan 19, 2010
    Cypress, TX
    It is a much nicer garage, can fit three cars if it didn't have a whole bunch of junk in boxes stacked in it! The MG is just outside the garage, in the upper pic, you can see the left side of the rear bumper behind the Camaro if you look closely. Once I get the Camaro done, it will be coming into the garage and get stripped down as well for a total rebuild.
  7. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    988
    11
    Apr 27, 2010
    Verona, ITALY
    Sorry for the little off-topic: Da-bigguy please can you measure the wall thickness of the tubes of your rotisserie? I'm in the process to designing one for me...
  8. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    I am guessing 3/16" steel. Some rotisseries might be 1/4", but I've read plenty of guys building them with 3/16" steel tube and they functioned fine.
    Speaking of, here is a nice set of plans for a rotisserie
    http://www.autobody101.com/rotisserie_plans.pdf
  9. Da-bigguy
    3,346
    73
    Jan 19, 2010
    Cypress, TX
    No need to apologize! I will check the wall thickness as best I can when I get home today and send you the info.
  10. Edem_Alive
    Edem_Alive Veteran Member Lifetime Gold Member
    464
    9
    Dec 18, 2015
    Montana
    I used 3/16". Works fine. Use three casters per side, not two! :D
