Project code name - Never Satisfied
Discussion in 'Project Progress' started by 1981LT1, Jan 7, 2017.
Shaved Door Handles?
Poll closed Oct 16, 2017.
  1. Yes
    1 vote(s)
    25.0%
  2. No
    3 vote(s)
    75.0%
  1. 1981LT1
    1981LT1 Veteran Member Lifetime Gold Member
    454
    34
    Dec 15, 2004
    San Antonio, Tx, USA
    Here is the interference from the mount adapter...
    And here is the "fix" for the problem...
  2. 1981LT1
    454
    34
    Dec 15, 2004
    Here is the alternator and PS bracket...
  3. 1981LT1
    454
    34
    Dec 15, 2004
    Here are the Speed Engineering headers. They fit great.
  4. 8pack
    2,450
    86
    Aug 29, 2007
    Pittsburgh, PA
    Looking good. How low do the headers hang? Amazing price on those.....
  5. 1981LT1
    454
    34
    Dec 15, 2004
    I actually didn't check that. I'll get them bolted back on and look.
  6. 1981LT1
    454
    34
    Dec 15, 2004
    Got the motor mount modified and got the crossmember cutout so I could get the compressor to fit. After some trimming I got everything cleared. Now, I need to get a hose assembly or block to bolt to the compressor so I know how much to notch out the frame rail.
    I know some of all ya'll are probably thinking I should get the high mount kit and call it day. Unfortunately, I think those kits are gross and look like crap. Plus, I want to keep the GM compressor and all of the factory type parts I can. If this means cutting up the frame rail to make everything fit, then that is what I am going to do.
  7. dave@ztech
    1,927
    260
    Mar 27, 2016
    NY
    I agree, the high mount looks funny, however, lots of people don't have the time or skill, or the patience, to plan, cut, fab and modify , so I understand why people choose it, and depending on the amount of problems you may run into, you may have wished you did as well, HAA HA
  8. 1981LT1
    454
    34
    Dec 15, 2004
    Luckily the only thing I have to worry about is finding a hose assembly that will sit tight to the compressor and keep me from cutting too much of the frame rail. More to follow.
  9. 80sz
    80sz Veteran Member
    2,881
    316
    Feb 2, 2014
    Buffalo,n.y.
    Nice mod to get it to work. Plan on boxing it back in? Some good progress.
  10. 1981LT1
    454
    34
    Dec 15, 2004
    Absolutely. Once I get the clearances I need, and I'm done with the bodywork, I'll blow apart the frame, weld up all of the holes, smooth everything out and powder coat it.
    80sz likes this.
