Prep Car for 5 Month Storage
Discussion in 'Camaro Questions' started by MotionClone, Oct 2, 2016.
  1. MotionClone
    MotionClone Veteran Member
    1,471
    279
    Jan 20, 2014
    away from the crazies
    What are some things I should do to prep the car for a 5 month cold storage? Car will be in a friends unheated but dry garage for the winter months.
    -mothballs to keep mice away
    -remove battery
    -tape off rocker openings and sidepipe openings
    what else?
  2. CasperCasper
    CasperCasper Veteran Member
    1,017
    119
    Aug 11, 2015
    Try a Dry-Z-Air unit. It essentially just collects humidity from the air but will fill up fast. The last thing you want is any mold in your interior !
  3. tom3
    tom3 Veteran Member
    11,319
    191
    Aug 1, 1999
    ohio
    Drive the car to dry out the exhaust and get the moisture out of the brakes, top off gas tank. 5 months is not that long, should be fine.
  4. wiseryder
    2,041
    38
    Sep 11, 2004
    belding,mi USA
    I put a boatload of dryer sheets in the car , under the hood, and around the car
    I leave Battery in but shut it off. that's all I do
  5. MotionClone
    1,471
    279
    Jan 20, 2014
    Thanks for the great tips! I assume the dryer sheets work better than mothballs to keep away the rodents? good change of rodents trying to find a warm place to winter over. Any other openings to cover to keep them from nesting?
    Ill be driving the car to the location and im mixing 100LL avgas to the regular gas before the trip. Excellent idea about the moisture absorbent, didnt think of that either.
  6. MotionClone
    1,471
    279
    Jan 20, 2014
    Anyone else want to chime in?
  7. 70-camaro
    70-camaro Veteran Member
    1,856
    302
    Mar 25, 2010
    marietta ohio
    I use moth balls,seafoam and leave a fan blowing. I never thought of taping the exhaust shut.
  8. harbone66
    3,500
    284
    Feb 15, 2011
    Central Illinois
    Over inflate the tires 10 to 15 pounds to keep the flat spots away
    Dryer sheets do work the best as a rodent repellant, put them every where inside and outside the car
  9. harbone66
    3,500
    284
    Feb 15, 2011
    Central Illinois
    Oh and instead of taping up the exhaust just put steel wool in the openings, mice can't stand steel wool
  10. 70-camaro
    1,856
    302
    Mar 25, 2010
    marietta ohio
    I put mine on dolly's that are rounded. Helps with tire radius and l can spin it sideways if I want. I can turn mine around 360 degrees in my garage.
