Power trunk opener?
Discussion in 'Electrical Systems' started by ULTM8Z, Dec 13, 2017.
  1. ULTM8Z
    ULTM8Z Veteran Member
    8,325
    45
    May 19, 2000
    Los Angeles
    My universal "ebay" solenoid took a dump after about 10 years... not too bad I guess...
    But I'm trying to see if there's a more factory option out there.
    Any thoughts?
  2. Twisted_Metal
    25,377
    327
    Those "Other" F-bodies (late 2nd gen) had them as an option and they fit the Camaros perfectly.
  3. junkyardZ28find
    736
    Mar 4, 2012
    des moines, iowa
    Theres no reason why you cant also use 78-88 gbody ones....easy to find and most had them anyway as did most 80s/90s Caprice, Paresienne, Buick Limited, etc
  4. ULTM8Z
    8,325
    45
    May 19, 2000
    Los Angeles
    Oh that's good to know!
  5. harbone66
    3,401
    223
    Feb 15, 2011
    Central Illinois
  6. ULTM8Z
    8,325
    45
    May 19, 2000
    Los Angeles
    Well I ordered a 78-88 g body one from eBay just now. Hopefully it works!
  7. ULTM8Z
    8,325
    45
    May 19, 2000
    Los Angeles
    It worked out great!
    It's certainly not a bolt-on per se, but it was easy to make to work. Just need to drill a couple of holes in the factory trunk latch to position it correctly. But once attached it works just fine.
    Thanks for the suggestion.
  8. Jim Streib
    223
    10
    Apr 6, 2004
    Saint Louis, MO USA
    I was kinda wondering if a hole or any modifications had to be done. On my 73 Nova, I had to drill a hole in the inner trunk lid skin to allow the lever off of the latch to trip open the catch arm of the trunk latch.
    Out of curiosity, did you take any pictures of the install that might help out others later on down the road ?.
    Jim
  9. ULTM8Z
    8,325
    45
    May 19, 2000
    Los Angeles
    Yeah no problem. I'l post some pictures shortly.
  10. ULTM8Z
    8,325
    45
    May 19, 2000
    Los Angeles
    Here's the photo. It looks factory enough I guess...
