power steering mount
Discussion in 'Camaro Questions' started by Anthony burns, May 21, 2017.
  1. Anthony burns
    Anthony burns New Member
    May 21, 2017
    About three years ago I saved money up and bought 79 Z28 as my first car. Since then a lot of work has gone into it I currently had to replace the motor so I could rebuild the original I have put a 74 Camaro 350 small block in it. and have decided to remove the factory AC now I'm having problems finding a bracket or Mound for my power steering can anyone help? I'm also new to the site and don't understand quite how it works yet
  2. buildinmy73
    buildinmy73 Veteran Member
    1,003
    Oct 20, 2007
    Bernardston, MA
    Welcome to the site .
    There are a few brackets for power steering . not sure which one you are missing with no pic.
    do u need the one on the back side that bolts to cylinder head/block.
    or the one with the slot in it that allows you to adjust the pump and lock it down?>
  3. CorkyE
    8,975
    159
    I used an Alan Grove bracket, not cheapest but perfect fitment.
  4. Twisted_Metal
    25,379
    327
    For now... You can remove the A/C compressor, belt and hoses and use the brackets that are there.
  5. larrylarry
    larrylarry Veteran Member
    1,312
    41
    Dec 22, 2011
    San Antonio Tx
    ^^^ that's what I did. I did trim metal off of them.
  6. CorkyE
    8,975
    159
    I originally did this, changed when I tossed the 2nd belt, likely warped the bracket when trimming. YMMV.
