Power Steering Hoses for LS2 swap
Discussion in 'High Tech Retrofits' started by kboxx, May 2, 2011.
  1. dave@ztech
    2,149
    315
    Mar 27, 2016
    NY
    I was just looking at the Russell line of make it yourself hoses and fittings, and you can build your own PS hoses, there's are rated to 2500 or 3500 and have all the handy different adapters and pre bent ends also
  2. mrfleet12
    mrfleet12 Veteran Member
    157
    16
    Aug 8, 2014
    West of Chicago IL
    Take a look at my build thread, I used Corvette pump, my stock gear box and stock lines.
    Link post #30
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,295
    70
    Feb 2, 2008
    SF
    Any chance you have part numbers to post
  4. mrfleet12
    157
    16
    Aug 8, 2014
    West of Chicago IL
    The fitting I used is from VMS Racing, the link in post #30 takes you right to it, they call it
    LS1 ENGINE SWAP CONVERSION 3/8 FLARE POWER STEERING BRASS ADAPTER FITTING
    $17.88..
    The hose I used was the stock 73 Camaro hose, it was pretty simple really..
    72BIGBLOCK likes this.
  5. 72BIGBLOCK
    2,295
    70
    Feb 2, 2008
    SF
    Thank you for the post ... that solves another problem :)
    mrfleet12 likes this.
