Powdercoat hood hinge?
Discussion in 'Body Restoration' started by Mr Sunshine, Sep 29, 2017.
  1. Mr Sunshine
    Mr Sunshine Member
    80
    Dec 12, 2016
    Missouri
    Anyone have experience with having their hood hinges powder-coated? I'm getting several components coated and considering the hinges as well. Just wondering if the thicker coat will restrict the hinge from rotating on the pins as it should or if it will affect the spring action??
  2. Twisted_Metal
    25,461
    348
    If you paint them... they will scuff and chip.
    Powder coat is more durable than paint but I think it will interfere with the function and probably scuff badly too.
  3. 70 Proof
    70 Proof Veteran Member
    327
    19
    Sep 28, 2014
    Southern Utah
    Recently had one powder coated. It was a little stiff at first but that didn't last long. It got chipped a bit while reinstalling the spring and scraped near the forward arm due to rubblng
    Against another part of the hinge. The PC cost $34
    Mr Sunshine likes this.
  4. Double R Restorations
    2,608
    20
    Jan 11, 2002
    VA
    I had a set done and they looked great, but the coating was too thick and interfered with the operation.
  5. Bandit723
    Bandit723 Veteran Member
    2,260
    265
    Oct 1, 2016
    Waupaca WI
    I powder coated my hinges came out good. I did have to to pull the springs and work the hinges loose but are working just fine after doing so. i did get some scuffing were the hinges rub against each other but i am pretty i would have the same thing if i were to have painted them. I paid $35.00 apiece to have them done.
  6. 70lt1z28
    1,583
    176
    Oct 3, 1999
    Beavercreek, Ohio, USA
    They do look good though black powder coated. I elected to zinc phosphate mine. Did it myself and it was really easy once I made a big enough tank(old SS sink). I can now watch them rust again! Seriously, I hope a more thorough playing last longer than the factory job did. Plus frequent oiling.
  7. wnmech
    wnmech Veteran Member
    724
    36
    Jul 20, 2014
    grand prairie tx.
    I was dumb and had my hood hinges powder coated. They looked beautiful but when I installed them and tried to close the hood I was met with virtually impossible resistance to get the hood to start to close. When I did get it to move it cracked the powder coating. In my opinion just buy new hinges and springs they dont cost that much. Mine fit fine and no paint chipping or closing issues.
  8. Zspoiler
    Zspoiler Veteran Member
    2,027
    101
    May 6, 2012
    Federal Way, Washington
    You can get the same affect by using VHT chassis epoxy .
  9. Zstar
    Zstar Veteran Member
    998
    195
    Mar 23, 2014
    Ocala, Florida
    I powder coated mine with the springs on. Did a black texture finish. Came out great. They were a bit stiff, but loosened up nicely with no chipping. Glad I did it.
  10. Mr Sunshine
    Mr Sunshine Member
    80
    Dec 12, 2016
    Missouri
    Hi Bandit723,
    Those do look great. Did you pull the spring before or after powder-coating? And how did you pull the spring off?
