pitman arm question
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Layne02, Feb 6, 2018.
  1. Layne02
    Layne02 Veteran Member
    104
    Jun 25, 2013
    Georgia
    I have wound up with a few different pitman arms somehow and was curious about the differences in power and manual arms. I have a couple that are straight and are about 7" from center to center. I have a couple that are shorter and have a slight curve in each end. Looking them up online I have seen the curved ones listed both ways. Anyone a pitman arm specialist?
  2. Skip Fix
    Skip Fix Veteran Member
    2,117
    Mar 21, 2007
    Katy,Texas
    Standard late 70s Camaro PS pitman is straight and 7". Pontiacs often had offset ones that are 6".
  3. Burd
    572
    98
    Oct 6, 2011
    I heard Camaro was shorter due to the position of the Po trac fuel pump. There's a company that makes a AM set up using a shorter camaro one to make steering faster.
  4. BonzoHansen
    As far as i know the Camaro one is longer which improves steering ratio.
  5. jamieg285
    jamieg285 Veteran Member
    1,275
    Jul 15, 2004
    Luton, England
    Curved left-right or up/down? I've seen the up/down ones on 3rd gen's.
  6. Layne02
    104
    Jun 25, 2013
    Georgia
    Curved up and down. I know at one point I had a manual box , seems like that one was really short and curved.
  7. mrdragster1970
    I have both at the shop, I can check or measure tomorrow to be exact.
    IIRC, the arm & center link are definitely different.
