Passenger Head TCS Sending Unit Availability?
Discussion in 'Original Drivetrain Topic' started by bkmont, Dec 24, 2017.
  1. Dave Nelson
    3,751
    1,105
    Dec 19, 2003
    Vineland N.J USA
    The connector is 2 prong female with a jumper (also green) on the rear of connector.
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    991
    17
    Jan 1, 2005
    Schererville,In.46375
    Does anybody know the AC Delco equivalent number ?
  3. roeville
    roeville Veteran Member
    1,143
    56
    Oct 9, 2000
    SF East Bay CA
    Not sure if this helps, in my notes I have 6489600 superseding to 25036520 (Delco G1865).
    Mike
  4. roeville
    1,143
    56
    Oct 9, 2000
    SF East Bay CA
    My original harness wire was a single terminal green wire. I believe all the part numbers for 71 eventually change over to the 2 terminal design.
    Mike
    From 1971 assembly manual
  5. bkmont
    bkmont Veteran Member
    1,036
    30
    Nov 14, 2010
    Pensacola, Florida
    Thank you for the pic. I believe I have several of that style connector attached to some old Corvette and Pontiac harnesses that I have stashed away in my workshop.
    So, it looks like I have all the components for the system-
    Firewall Relay - GM original
    Intake Manifold Solenoid - GM original
    2 Prong Temperature Sending Unit - Borg-Warner replacement
    Transmission Switch - GM original
    I also have the guide that states how to check it out -
    https://www.ncrs.org/forums/archive/index.php/t-114990.html
  6. Budz
    2,977
    45
    Mar 17, 2002
    Ashburn, Va USA
    Don't forget the clip to hold the green wire. If you need one, let me know :bowtie:
  7. bkmont
    1,036
    30
    Nov 14, 2010
    Pensacola, Florida
    Thanks Bud. I have one already.
    Bryan
    Budz likes this.
