P0442 code on my silverado
Discussion in 'The BS Topic' started by 80sz, Dec 2, 2017.
  1. Mike N
    Mike N Moderator Staff Member Lifetime Gold Member
    2,261
    276
    Jan 13, 2002
    Spencerport, NY.
    Check the truck side of the fuel pump harness. I can't remember if it's a three or four wire setup, but on the trucks of that vintage the ground wire on the truck side was a short wire that screwed to the top side of the frame rail, close to where the filler tube passes over the frame. The wire would corrode there and cause a high resistance condition in the ground circuit.
  2. BonzoHansen
    All good. bad pump I took it all out. impeller just jams you can hear it
  3. Mike N
    2,261
    276
    Jan 13, 2002
    Spencerport, NY.
    Vato Zone pump??
  4. BonzoHansen
  5. BonzoHansen
    Delco or carquest brand any good?
    Does airtex make car quest pumps.? Are they any good?
    Or are they all the same?
  6. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    Airtex lasted about a year in mine. Had no choice, it was all I could get on a Sunday. Carters have sucked. I just put a Delco in.
  7. BonzoHansen
    One new delco pump in today. All is now well. Hopefully it remains that way. Not fun 30* and windy, but I needed to get it done.
    Waiting for spectra to call me back on the warranty.
  8. BonzoHansen
    to make Dave cry. Mike has seen much worse.
    just an example
    Leaking fuel lines!
    shiny & new. i painted it before I put it in
    Sender lines kinda beat, but not as bad as i expected. Pump had been replaced at some point, and I think the fuel lines were too.
    the aftermath
    both WCs looked like this, neither were leaking. the line broke upstream more. Feed lines to front hoses looked equally old & thin
  9. BonzoHansen
    Mike, this is why I think the fuel lines were previously changed or at least monkeyed with. This is where the two return lines met. Should be a union. WTF is this? Tht is no GM o-ring line connector. lol I could not get it apart.
  10. Mike N
    2,261
    276
    Jan 13, 2002
    Spencerport, NY.
    Looks stock to me, Scott. Pull it apart and you'll find a flared connection inside that. GM also used those on brake lines in the LeSabre/Park Avenue platforms for the brake lines.
