OUTER LOWER WINDSHIELD MOLDING - 1970 vs 71-81?
Discussion in 'Camaro Questions' started by Cue-Ball, May 12, 2010.
  1. flowjoe
    7,947
    21
    Feb 7, 2006
    SoCal
    Snicker -snicker, chorttle...you said BOZO, snort-snort, chorttle:)
  2. COPO
    15,974
    190
    I don't recall when they stopped drilling into the window trim, but the newer style black mouldings do not get mounted that way. If I recall on my 77,78,80 Z28's, they were I believe shoved up at the pillar end and screwed in at the other end.
  3. olstyle
    olstyle Veteran Member Lifetime Gold Member
    8,649
    Jan 27, 2008
    Crestwood IL.
    I forgot about these pieces till I saw this thread. Here's a few pics of the ones off my 74. No screw hole in the window trim, only one in the cowl. Both my screw holes are broke, need to figure something out. Don't really want to spend $22 apiece for these but will if I have to :eek:
    Is it safe to assume(think)that these will mount "under" the window trim?
  4. COPO
    15,974
    190
    The short arm gets jammed under the window moulding.
  5. olstyle
    8,649
    Jan 27, 2008
    Crestwood IL.
    Thanks Mark
  6. Twisted_Metal
    25,389
    329
    Yup... The end of the molding has a channel in it... The tab fits into the channel.
    No screw through the molding on the later years.
  7. 74Z28GC3
    74Z28GC3 Veteran Member
    1,447
    11
    Sep 1, 2000
    North Pole, Alaska
    Does anyone know what type and size of screw is used to attached the 74 or later Camaro lower windshield black plastic moldings?
    Thanks,
    George
