ordered a wideband im tired of
Discussion in 'The Carolinas (North & South)' started by Mwilson, Mar 30, 2017.
  1. Mwilson
    Mwilson Veteran Member
    ordered a wideband im tired of doing the around the block seat of the pants guess and tearing the carb apart
  2. Coadster32
    1,398
    73
    Oct 2, 2013
    Milford,CT
    What kind, and keep us posted. I just redid the exhaust on my Camaro, and put bungs in right after the collectors. (Didn't buy anything for them yet.)
  3. Mwilson
    Its called
    APSX D2
    Looks to very very easy to see while driving and the kit looks like it has everything
    GsLawLess79 likes this.
  4. GsLawLess79
    GsLawLess79 Member
    64
    12
    Oct 17, 2016
    Goldsboro, NC
    Bungs? Educate me???
  5. COPO
    16,332
    261
  6. Mwilson
    Installed the wide-band tonite and did 3 baseline pulls out on the road to see where Im at
    Idle - 14.8
    Cruise high gear 35 mph - 14.2
    Cruise high gear 45 mph - 14.6
    Cruise high gear 55 mph - 15.0
    WOT high gear pull 35 mph - 60 mph steady 11.8 the entire pull
    750 Annular 74 primary with 8.5 pv and 94 secondary
  7. Coadster32
    1,398
    73
    Oct 2, 2013
    Milford,CT
    Way cool to know these numbers. Should really help you dial in stuff. I was told with a medium cam overlap that I might not be able to use one of these for checking idle, as it'd mostly likely always read rich.
  8. Mwilson
    whats your cam? I think you'll be fine I have had some radical cams before the one I have now is fairly mild
    245-252 @ 50 - 106 LSA .555 lift
  9. Coadster32
    1,398
    73
    Oct 2, 2013
    Milford,CT
    Honestly, not sure. Was in the car when I bought it. It's not crazy, but you can tell one is there at idle. Evens out pretty quickly. Would be nice to A/F gage it.
