Optimal performance tire size for 15x7 z28 wheels
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by vintagecarenthusiast, Sep 20, 2018.
  1. vintagecarenthusiast
    vintagecarenthusiast New Member
    27
    Sep 26, 2017
    80sz, I guess if I can squeeze a 275 50 15 on the back then I could squeeze a 275 60 15 on it? If so I guess I could just use what I have until after I get the car back out after winter. I currently have 275 60 15’s on the back. What is the optimal tire pressure? I don’t care about treadlife since they are basically free to me anyway.
  2. Zspoiler
    Zspoiler Veteran Member
    2,916
    191
    May 6, 2012
    Federal Way, Washington
    I didn`t go any bigger than P245/60-15`s ,Because with the wheel offset and the tire pressure (35 PSI) ,Because it would rub on the outer lip,
  3. 80sz
    80sz Veteran Member
    2,898
    320
    Feb 2, 2014
    Buffalo,n.y.
    26" tall and radial. It's tight for a 7" rim as they say7.5 minimum. Mine never fell off
  4. djorgensen3
    djorgensen3 Veteran Member
    455
    47
    Oct 15, 2009
    Peoria, Az
    I bet it wouldn't cost much to get the wheel welded where the leak is. I'd bet its a small pinhole or something. Now if it's cracked, different story and probably replacement is best but there are wheel repair places that could easily fix the wheel and not be too costly.
  5. Twisted_Metal
    26,358
    638
    I have 255/60-15 on the rear of mine but the 245/60-15 is better on a 7" wheel.
    (Less distortion of the contact patch.)
    You can't run the 255s over 30 PSI without suffering severe center tread wear.
  6. vintagecarenthusiast
    27
    Sep 26, 2017
    I'm leaning towards 235 60 15 in the front and and 245 60 15 in the back based off of everyone's recommendations. Summit and Jegs sale ends today so I guess today is the day that I pull the trigger. So 245 60 15 in the rear should perform as well as 235 60 15? handling-wise, highway use, sidewall stability in turns? I'm not racing or anything, just using for driving it on the street. Thanks everyone for the input!!!
  7. bkmont
    bkmont Veteran Member
    1,079
    40
    Nov 14, 2010
    Pensacola, Florida
    I like the the new Firestone Radial Wide Ovals. They handle very well for a street tire on my 70Z with a Rancho Challenger Suspension kit on it.
  8. johnnycamaroz
    johnnycamaroz Member
    55
    Jul 22, 2014
    tucson,az
    nice what size are those , they look good FR6015?
  9. vintagecarenthusiast
    27
    Sep 26, 2017
    I love those wide oval's. That's an expensive tire but a great look. ~$320/tire?
