Operation LS7
Discussion in 'High Tech Retrofits' started by badazz81z28, Mar 5, 2017.
  1. redriderjf87
    redriderjf87 Veteran Member
    117
    11
    Jan 23, 2016
    Quad Cities, IL
    Can't wait to see the power numbers on this thing.
  2. nobreaks254
    nobreaks254 Veteran Member
    454
    Jul 14, 2007
    aberdeen, SD
    your cam is very close to my custom specd cam from WCCH. 234/244 .650 lift. This was specd for their ported Brodix castings. Were you going with touched up stock heads?
  3. badazz81z28
    14,716
    166
    Las Vegas, NV
    ^^the heads were CNC ported to 265s
  4. badazz81z28
    14,716
    166
    Las Vegas, NV
    Well, the most exciting part of this ordeal is where to put the oil tank....man I now wish I just converted it to wet sump
  5. Bill70
    Bill70 Veteran Member
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    How big of a tank? I put a 3 gallon tank where the battery used to go. Easy oil changes because the drain plug is right at the lower valence.
  6. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
  7. badazz81z28
    14,716
    166
    Las Vegas, NV
    ^^ Awesomeness. I have a 2.5 ga
  8. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    Here are some of my tank mounting pictures. As I recall I had to make accomodations for the fact that the core support is not perfectly flat in that area but I cut and added some metal as needed.
  9. DB Z28
    DB Z28 Veteran Member
    534
    32
    Nov 30, 2003
    Fond Du Lac
    That's how I,m doing mine where the battery was.
