?? on serpentine belt setup water pump ???
Discussion in 'Engine Topic' started by buildinmy73, Jan 22, 2011.
  1. buildinmy73
    buildinmy73 Veteran Member
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    have a sbc 406 im putting a sepentine setup on it froma 88 iroc Z was wondering what to use for a wterpump? reverse direction noral etc please any help thanks DAN
  2. tedm_SS
    tedm_SS BANNED
    90
    Jan 9, 2011
    Missouri
    reverse rotation, but same direction of flow. Saw some cheap ebay aluminum versions the other day. I think my buddy has the same set-up. I will chime him on what brand he used.
  3. Knuckle Dragger
    Knuckle Dragger Administrator Staff Member Lifetime Gold Member
    13,482
    546
    Nov 2, 2002
    Waddell AZ
    Get a pump listed for the IROC. It's re reverse rotation pump.
  4. buildinmy73
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    Ok so I should get a pump for the iroc? Will it bolt up correctly?
  5. Kamikaze
    1st Gen Small blocks 1955-1999 have the same mounting pattern.
    Water pumps were short style / standard rotation from 1955-1968
    Long Style Standard Rotation from 1969-1999.
    There were exceptions with the Corvette and Monzas in the mid 70's up that had short height but the mounting was still the same.
    Factory Serpentine systems used long style water pumps with reverse rotation from 82-99 on Camaro's, Caprices, and the C/K trucks. Even the 4.3 S-10's and Astro vans had the long pump with reverse rotation. Any of these will be fine for you application.
  6. buildinmy73
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    Thanks for clarifying that
  7. buildinmy73
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    i also noticed while trying to find one for a 88 5.7 v8 it lists both clockwise and counterclockwise not sure which one i need and y they list both ?
  8. amargari
    amargari Veteran Member
    1,223
    Feb 19, 2003
    Morristown, NJ, USA
    Kamikaze,
    I don't think the serpentine systems showed up on the Camaros until 1988. The pre 88 TPI engines still had V belts.
  9. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    Just get an electric. :D
  10. Philip
    Philip Veteran Member Lifetime Gold Member
    1,806
    May 30, 2006
    Marana, AZ
    Order one for an 89 IROC. I used an aluminum Edelbrock with my system.
