old racer brown cams
Discussion in 'High Performance Modifications' started by hubba, Aug 5, 2006.
  1. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    I thought Racer Brown was a Crane owned company?? Could be wrong though.
  2. hubba
    hubba Veteran Member
    204
    Jul 21, 2006
    i am hoping for a nice strong street motor out of this cam. HeadWizard did you ever run a roller from them, with a small lift like this one?
  3. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Isn't George actually Racer Brown??
    I have an SASE letter back from him, I think, back when I was looking for a cam for my 454 before I turned it into a 496.
    pdq67
  4. hubba
    204
    Jul 21, 2006
    well when i first got this cam someone told me that racer brown was this guy.
    Company: Racer Brown
    Contact: Jim Doyle
    Phone Number: 410-866-7660
    Email: None
    Specialty: Custom Cam Grinding
    i call him and he knew what i was talking about but he had never ground one.
    and the spec at .050 was not it the book he had. He said he would have to find that lobe template and measure it if he could find it.
    Now i need to find me some good valves that will take roller spring at a good price that flows well my other set of valves might not be good enough.
  5. hubba
    204
    Jul 21, 2006
    cam came in looks like new even if it has been in a box for 45 years. i can't wait to run it, never had a roller before.
  6. hubba
    204
    Jul 21, 2006
    put my new short block together and measured the cam @ .010 it was 292 duration and @ .050 it was 240 duration. don't think i will have a problem running pump gas this time going to be about 10 to 1 compression.
  7. Air_Adam
    Air_Adam Veteran Member
    Man, that thing is gonna sound like the world is coming to an end lol.
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    George replied back to me years ago.
    As for the CC 268HE, UDHarold designed it for them of Ultradyne fame!!
    As well as the new Lunati VooDoo hy-cam line..
    pdq67
  9. hubba
    204
    Jul 21, 2006
    called my head porter and he broke through on a exhast bowl. head had a little bit of core shift. good thing it can be tigged back together. just has a pea size hole at the bottom by the valve guide.
  10. 02sunsetz28
    02sunsetz28 Veteran Member Lifetime Gold Member
    103
    Mar 8, 2004
    maryland
    Thought I would reply to this 11 year old thread instead of starting a new one since I emailed Jim in Baltimore for some cam specs of the EH4.
    Here's one I just pulled out of an '86 block. Whats everyones opinion on the wear on the end of the cam. You can also somewhat see it at the rear of the block, and lastly cam lobe wear.
    And I'll add the front cam bearing too...
