old brakes dont work the greatest
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Mwilson, Feb 26, 2018.
  1. Mwilson
    Mwilson Veteran Member
    Im switching to 4 wheel disc I found a good deal on a kit on ebay lol anyway is there any reason I need to change master cylinder or proportioning valve?
  2. CorkyE
    9,526
    263
    You'll need a disc/disc proportioning valve, master cylinder is okay.
  3. Mwilson
    going ahead with the install Saturday fingers crossed!! lol is a "Summit Racing" kit
  4. dave@ztech
    1,229
    131
    Mar 27, 2016
    NY
    You may want to get the manual adjustable one, to set up the front rear, more to your liking
  5. Zspoiler
    Zspoiler Veteran Member
    2,665
    155
    May 6, 2012
    Federal Way, Washington
    Use a proportioning and master cylinder from a 1979-81 Firebird /Trans Am,
  6. Mwilson
    I bought an OE disc/disc proportioning valve I dont want another thing to adjust! lol
  7. Skip Fix
    Skip Fix Veteran Member
    2,074
    Mar 21, 2007
    Katy,Texas
    But depending on different tire sizes, different front or rear spring rates you will need some adjustment as the factory ones are designed with the bias for the complete factory system.
  8. ULTM8Z
    ULTM8Z Veteran Member
    8,656
    154
    May 19, 2000
    Los Angeles
    You need to size the master cyl piston to the caliper pistons or you'll have a pedal that's too hard or too soft.
    As far as prop valve, I used a late 70's WS6 Firebird 4-wheel disc and it works great.
