Oil burned on plugs fouling issue.
Discussion in 'Troubleshooting & Diagnosis' started by Beaber89, Mar 6, 2018.
  1. CorkyE
    9,882
    319
    Did you have this rebuilt at a reputable shop - is going back to them an option?
  2. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    Unfortunately this rebuild is two years old so I don't believe it's in any warranty. I just don't drive it much is why the miles are around 1000.
  3. CorkyE
    9,882
    319
    It won't hurt to call the guy and let him know what's going on. He might be helpful, even after a couple years.
  4. RS1979
    3,316
    500
    Jun 18, 2013
    Memphis, TN
    It's worth a shot. All he can say is no.
  5. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    Compression tested on a few cylinders ran compression on 2, 6 and 8. 2 is 155 6 is 155 8 is 151 roughly . The gauge was bleeding itself off. The intake valves are gross on all of them likely from running nasty rich for a while. But I'm looking at the runners of the heads on 6 and 8 now. There's a good obvious difference between them. Looks like 6 may have been dragging oil in through the intake gasket but I'm not really experienced enough to say. What do the fellas think ? Pics are sideways but hopefully you can tell
  6. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    Or their not sideways but upload showed it sideways
  7. 74BIBELOT
    74BIBELOT Veteran Member
    840
    50
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    Check the spark plugs wires or change 6/5 wire.
  8. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    Wires are new 9mm firepower by Taylor cable. Distributor is new, I checked the cap for bad posts on 6 and 8.
  9. cadillac_al
    cadillac_al Veteran Member
    705
    50
    Apr 22, 2015
    Maine
    It sounds like a simple intake gasket failure to me. I'm pretty sure your builder will say the same thing. Why is the question. Was it a cheap gasket or an old used intake manifold or were the heads shaved altering the mating angles?
  10. Z28zz383
    Z28zz383 Veteran Member
    793
    May 11, 2012
    Florida
    Are those "vortec" heads? If so you may need the GM gaskets. I tried the reg blue type gaskets on my ZZ 383 with fast burns and had similar issues until I used the GM vortec gaskets. Stopped my intake leaks. Big runners are not giving much sealing surface from what I can see from the pics.
