Oil burned on plugs fouling issue.
Discussion in 'Troubleshooting & Diagnosis' started by Beaber89, Mar 6, 2018.
  1. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    So I have a small block 350. Rebuild on the motor has been maybe 1000 miles ago. I've been having issues with cylinder 6 and 8 fouling the plugs put and when I pull them it looks to have burned/seared oil on them. I'm trying to get most likely ideas from the people as to what the problem could be. This is cylinder 8 plug. My carb is tuned well, idle at 14 afr, cruise at 13 afr, wot at 12.5 or so. This plug was put in yesterday. The car was run street and highway for maybe 45 minutes so that's how long this plug has operated. Hit me with some knowledge please so I can get it sorted out.
  2. CorkyE
    9,358
    238
    Several things can be the culprit; bad valve seals or guides, intake manifold not seated, aligned, or torn, and piston rings not seated in bore. Bad valve guides and/or seals will usually puff smoke on startup or after you coast for a while the mash back down on the gas. Intake gasket, you'll have to pull the intake off unless someone knows a magic trick. You can do a compression check for rings. Good luck.
  3. budro6968
    budro6968 Veteran Member
    2,161
    287
    Apr 2, 2016
    Jax Florida
    X2 on compression check, The easiest is the compression check.
  4. COPO
    16,324
    258
  5. budro6968
    2,161
    287
    Apr 2, 2016
    Jax Florida
    Nifty. The H/F type got a lot of bad reviews. How much did it cost to make yours?
  6. COPO
    16,324
    258
  7. tom3
    tom3 Veteran Member
    10,974
    120
    Aug 1, 1999
    ohio
    That's real quick for a valve guide or seal. I'm guessing a broken ring on assembly being a new build. Hope not!
  8. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    So let me ask this . With the problem occurring on cylinder 6 and 8 could the cause be head gasket allowing compression and such traveling between the two .
  9. CorkyE
    9,358
    238
    Yes it could, but with a blown head gasket, you likely see other issues like steam coming out the exhaust pipe or coolant bubbling in the radiator. What you're describing doesn't point to blow head gasket at this time.
    As mentioned above, easiest to check will be a compression or bleed down. If all is good, then pull the intake to check for bad gasket.
    You can check with parts stores in your area, many have loaner tool programs. You might be able to get a compression or leak down tester that way. They generally come with instructions or we can help here.
    Where are you located, might be another NastyZ guy nearby.
  10. Beaber89
    Beaber89 New Member
    22
    Feb 3, 2017
    Oklahoma city is where I'm at.
