odometer not turning
Discussion in 'Electrical Systems' started by 1972RS/Z28, Sep 8, 2011.
  1. 1972RS/Z28
    1972RS/Z28 Veteran Member
    492
    Aug 11, 2005
    Aylmer, Ontario, Can.
    I heard my speedo clicking and I loked down and saw my speedo jump, then I noticed that my odometer was stuck at 2100.6. It will move to between 6 & 7 and then snap back to 6. What could be the problem? I've had it apart a couple times so removing it AGAIN just sucks. thanks Darrin....
  2. ls777z
    ls777z Veteran Member
    2,098
    Feb 19, 2000
    Clay,NY
    It might not be the odometer itself but the cable. I would check at the transmission end and see if everything there looks ok . Also, check to see if it is kinked or bent.
  3. southview
    southview Veteran Member
    115
    Mar 16, 2006
    Viera, FL
    had the same problem.But,when I took it apart the second time I used some dry silicone grease and lubed everything in the housing.Has been working ever since.
