Non Climate controlled garage tips
Discussion in 'Garages, Workshops & Tools' started by Blu-By-U 79Z, Jan 2, 2017.
  1. 351maverick
    351maverick Veteran Member
    3,489
    329
    Aug 11, 2010
    erie, PA
    FANS!!!
    I have 2 big box fans running 24/7 in my heated garage just to move the air around
    Blu-By-U 79Z likes this.
  2. 70-camaro
    70-camaro Veteran Member
    1,949
    323
    Mar 25, 2010
    marietta ohio
    I have a 52 inch industrial ceiling fan on a reastat so I can speed it up or
    slow down as needed.
  3. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,543
    15
    Feb 11, 2009
    Kentucky
    Wow thanks for the responses everyone. If you look in my build thread there are pictures of my booth as I call it. We framed up 2 walls and a ceiling. I have a home made concrete floor. I have issues with water coming under the wall during heavy rain. Ive been trying to The rest of the building is just gravel floor. The booth has one window in the back and then a pair of barn doors at the front. Then a walk through door in the right hand wall.
  4. John Wright
    14,472
    148
    Aug 9, 2002
    Rustburg, Va
    Keep air moving and see if you can find a way to keep temperature swings to a minimum. If the floor and or your tools gets cold and then the air warms up, the moisture in the air will condense on the cold floor and tools.(sweat)
  5. 70-camaro
    1,949
    323
    Mar 25, 2010
    marietta ohio
    If those are landscaping pavers you may be getting moisture thru each seam.
  6. 70lt1z28
    2,639
    392
    Oct 3, 1999
    Beavercreek, Ohio, USA
    May also be getting moisture up through the floor. Was a vapor barrier put down before the floor was set? As others have said, moving air will be the cheapest. If the car is stored during the winter, those big zip up bags may work packed with desiccant. That may be expensive though.
  7. Blu-By-U 79Z
    5,543
    15
    Feb 11, 2009
    Kentucky
    there was no moisture barrier under the concrete. most of it was already there and the landscaping block was just a way to make a solid floor. Ill check into that more. Thanks guys! You guys rock!
  8. indyzmike
    indyzmike Veteran Member
    551
    Mar 21, 2002
    Richland Center, Wi
    For winter storage, I put down a thick carpeting under the car for insulation. I also run a ceiling fan that is not directly over the car to keep air moving under the car. For tools you can put a heating pad in the bottom drawer of the toolbox. You don't have to run the fan and heater all of the time, just when the conditions are bad. A sheet of plastic under the carpeting might help too. If all else fails, you can run a window a/c for maximum moisture removal.
  9. giggity
    giggity Veteran Member
    741
    23
    Mar 18, 2013
    Pearland, texas
    like everyone says....air flow.
    One thing that drastically helped my garage, is that I sealed the floor, no moisture in my garage...ever.
  10. BonzoHansen
    Rain is diffeent than condensation. Can you do anything to mitigate water runoff while it is raining? Gutters, etc...
