New NPD Dash Pad
Discussion in 'Interior Restoration' started by garyandcindy, Jul 9, 2013.
  1. buildinmy73
    buildinmy73 Veteran Member
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    i used so carbide deburring bits . same ones using when porting heads intake etc. they make them in all sorts of shapes and sizes
  2. Zulu28
    Zulu28 Veteran Member
    231
    16
    Dec 19, 2013
    Vancouver, BC
    Interesting thread, good job Badazz
  3. younda
    younda Veteran Member
    103
    23
    Jun 26, 2015
    MA USA
    I put in the NPD dash pad and it fits good so far. I don't understand why the NPD mounting clip kit doesn't include the screws to use on the driver's side.
    Can someone tell me exactly what to use? Does a 1/4" screw work? Should it be #6, #8, #10???
  4. Green hornet
    Green hornet Veteran Member
    1,314
    192
    Oct 11, 2015
    North Bay, CA
    image.jpeg Has anyone had this issue with new NPD dash?
    I bought my NPD dash last December as soon as they came off back order. I installed it in late January. When I installed it it had a slight raised area in front of the speaker between the two mounting clips on the left. I noticed a month ago that the raised area is larger. I'm not sure if this can be corrected. I have read that other members have removed some material above the cluster area but I'm not sure that would apply with this issue. Any ideas?
  5. supwicha
    supwicha Veteran Member
    164
    Feb 23, 2014
    Victorville, CA
    Does it feel soft and pliable in that area? Is there any chance that pressure from both the left and right side of pad towards the center causing it to lift?
  6. Green hornet
    1,314
    192
    Oct 11, 2015
    North Bay, CA
    No. If I apply pressure from the top in that area and pull it back slightly it will sit down. As soon as I let go it pops back up. I have looked at the clips to make sure there in properly and tight.
  7. badazz81z28
    14,647
    160
    Las Vegas, NV
    I got a raised portion like that on mine too. I have just chopped this all up as the pads are no Perfect
  8. TommyRS70
    TommyRS70 Veteran Member
    836
    16
    Jan 31, 2004
    KY
    Purchased mine when the latest, best version was first available and it is starting to develop the same lift/curl. Not sure how much better these will end up being in a few years of temp changes. Hopeful but not very optimistic. I'm working on a back up original, just in case.
  9. TommyRS70
    836
    16
    Jan 31, 2004
    KY
    1007172311a.jpg 1007172246a.jpg Had to gorilla glue in 2 sheet metal reinforcement plates above gauge cluster because there were no inserts to screw in the dash pad to metal dash..
    Also had to drill pilot holes in the pad next to the 2 top gauge housing screw holes to accept the guide pins on the back of the housing....more iterations needed to make this NPD pad better...
  10. TommyRS70
    836
    16
    Jan 31, 2004
    KY
    Original pad with nylon inserts. These are missing from latest NPD pad.
    Metal dash anchor tabs that the two screws pass through.
