New member - old car..
Discussion in 'Project Progress' started by 71RS6SPD, Nov 15, 2016.
  1. 71RS6SPD
    71RS6SPD Veteran Member
    154
    Nov 14, 2016
    Getting the wires into the doors was a pita. First set of boots were too short. I found longer ones.. Used 7/8 grommets from the local hardware store - worked out well. I was able to install these with the doors on! Placed the drill inside the door with a long extension. I will be removing doors when I paint next year.
    There are plenty of wires in there - although it may be maxed out.
    1 pr 12ga speaker, 3 for mirrors, 2 for windows, one 10 ga. for door pop and one for courtesy light. All relays are under dash.
  2. 71RS6SPD
    154
    Nov 14, 2016
    Moving along..
    Installed willwood MC and 8" dual diaphram booster. (needed a vac canister to work well)
    I installed a front brake upgrade.
    Had to trim old caliper mounts off spindles and drill/tap mounting holes for brackets.
    Did a Wilwood 12.8" rotor 6 piston caliper upgrade..
    Audio/Interior - initial mock-up of sub box and woodwork.
    Rear speaker mounts (notice no rear deck!)
    Ready for urethane.. There will be lots of coats..
    Interior getting there.. Console finished.. just made the drink/phone holder
    Engine bay getting there.. Just added the vac res behind the drivers headlight. It did the trick for the low vac engine with 8" brake booster. IMG_20170911_082848311_HDR.jpg
