New location for MSD box
Discussion in 'Competition Camaros' started by muscl car, Feb 15, 2018.
  1. muscl car
    Since putting carpet in I had to remove the 7AL2 box and since all my wiring is in this location I decided to mount it here
    I'm going to use 6 gang terminal blocks for the wiring so it will be easily removable . The wiring isn't completed in this pic and/or is the MSD box
  2. Zspoiler
    Zspoiler Veteran Member
    2,664
    154
    May 6, 2012
    Federal Way, Washington
    With all the heat from the supercharger I mounted mine on the passenger transmission tunnel. Using the MSD shock mounts I mounted my Crane Hi-6 TR So it would be out of the way of the passengers feet
    muscl car likes this.
  3. muscl car
    I tried that location or anywhere on the trans tunnel and just way to big to fit nicely . I rarely have passengers and have even considered removing the pass seat
    EDIT ...
    The old location was on the toe board very close to the firewall and was just to hard to get to the RPM pills
  4. mrdragster1970
    That's where mine is on the 70 1/2, works perfect there.
    Easy to work on, easy to change chips, plenty of air space around it.
    Mine is on a 5-6 inch stand to keep away from the header heat.
    I don't have a seat, the N2O bottle is where the seat goes.
  5. muscl car
    Awesome !! , I picked a good location for it then . I do have it mounted on Sprint car MSD magneto box bracket along with the vibration damper mounts . its 2" above the floor so as you mentioned it is receiving adequate airflow
    This is the box mount I'm using
    http://www.jegs.com/i/MSD-Ignition/...MIq9X-i6Gp2QIV1C-BCh3s7gSbEAQYBCABEgIMMvD_BwE
  6. Zspoiler
    2,664
    154
    May 6, 2012
    A Crane Hi-6 TR is the same size as an MSD box ,So it works for my application.
  7. mrdragster1970
    I had the heating guy next to my shop just fold up a piece of thick sheet metal.
    That looks nice, but I wanted mine much higher, I don't have exhaust, so it gets real hot in that area.
    Also being so tall, I was able to mount the window switch on 1 leg, and the N2O relays on the other leg.
  8. muscl car
    Got the wiring done this afternoon and nice and clean install
  9. frankz
    frankz Veteran Member
    2,070
    Aug 24, 2009
    Illinois
    Forgive me , but why finalize the location before gitting rid of the clunky dash ??
  10. muscl car
    No need to replace the dash !!!:) , it's not a concourse or show pony car , just a go fast car !!
