New Adventure
Discussion in 'Project Progress' started by 79supergasdriver, Apr 1, 2017.
  1. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    753
    Jun 22, 2005
    Wichita, KS, USA
    Brought a few more big pieces home the other day...
    T56 Magnum with shifter and throwout bearing, clutch disc and pressure plate, driveshaft and fabricated crossmember. Just needs a flywheel and engine to turn it all
  2. 79supergasdriver
    753
    Jun 22, 2005
    Wichita, KS, USA
    Got some good and bad news when I tore down the engine. Good news is it's a 4-bolt block with seven tapped holes for trans mounting, provisions for dipstick on both sides, and 2-piece seal. Bad news is #8 piston was missing a chunk of skirt and all buggered up on one side. Also bearings are trash. Looking at complete rebuild now.
    Got my annual bonus from work the same day these heads appeared on a local buy/sell/trade Facebook group:
  3. Zspoiler
    Zspoiler Veteran Member
    2,157
    112
    May 6, 2012
    Federal Way, Washington
    Well now you can have it built the way you want .And with any modifications to address any issues .
  4. 79supergasdriver
    753
    Jun 22, 2005
    Wichita, KS, USA
    Yea
    Yeah, I know it's a good thing in the long run, but for now it just means significant delays waiting on funding.
  5. Zspoiler
    2,157
    112
    May 6, 2012
    Its takes a while doesn`t .It took me a long time to build mine.
  6. 79supergasdriver
    753
    Jun 22, 2005
    Wichita, KS, USA
    Big updates after a long absence:
    Received a 0.30 over Gen 1 SBC donated by my brother-in-law. He told me it was a running engine, and I was able to turn it by hand, but heard some noise under the timing cover. I removed it to find two of the cam bolts had spun loose and were chewing up the cover and the locating dowel was sheared off. Needless to say the cam had wandered forward and the lifters/lobes were trash. Also there was no bolt holding the harmonic balancer to the crank. Repaired easily enough with the Melling "RV" cam kit, timing set, and some gaskets. Threw my accessories and intake on it; now I have what should be a running engine awaiting install. I'll run this one while I take my time building the other engine the way I want it.
    So naturally I thought to mate up the T56 at this point and drop the whole lot in together.
    Dial-indicating the bellhousing was time-consuming but not nearly as troublesome as I thought it might be. I made a huge mess removing the T56 front cover because I didn't bother to check if fluid was present beforehand. The farthest indicated was 0.004 off center. Finding a decently-priced flywheel for the 26 spline, 11" clutch on a 2-piece RMS block was a chore, but I eventually settled on a 31 lb. steel boat anchor. Bolted it on, installed the roller-bearing style pilot, got the clutch aligned and bolted on, got the cast aluminum bellhousing bolted up (had to drill and tap top center hole in block).
    Go to slide the trans onto the bell housing only to learn this particular unit features the slightly longer LS input shaft. It bottoms out in the crank before the trans meets the bell housing. Probably should have measured that before doing all this, but what the heck. I already had all these pieces and wasted nothing but some time in trial and error. In all fairness the guy I bought it from had used a QuickTime adapter housing but sold it separately before I could pick up the package, so he wasn't sure if the cast aluminum piece supplied by Hurst would suit the application or not. So now I'm at a crossroads and going cross-eyed trying to figure out what I need to make this all work together. I've read a thousand different threads and tech articles about this Gen 1 SBC/T56 pairing but can't seem to find any of the various adapters, spacers, cast or fabbed housings, etc people reference. According to the wide world of Interwebs McLeod makes one, Mr Gasket/Holley Parts Group makes/made one at one time, Hayes makes/made one, QuickTime still makes one, and a handful of other brand names have produced these things but the only part I can readily find is the QuickTime version for ~$600 bucks!
    Pics will be added as soon as the Feds decide they aren't porn or espionage and allow the files to download from the exchange server
  7. Twisted72
    Twisted72 Veteran Member
    295
    35
    Nov 8, 2015
    New Albany, Indiana
    I feel your highs and lows, everything happens for a reason just have to step back and look before you leap,
  8. 79supergasdriver
    753
    Jun 22, 2005
    Wichita, KS, USA
    Things have been progressing slowly. Wrapping up my first bachelor's degree, working full-time overnights, raising three kids, and planning a wedding (happening in two weeks!) have relegated the car to the bottom of the list. As it sits right now, I've got the engine and trans mated properly using the Quicktime adapter housing and the pair is installed into the car. Got the crossmember and driveshaft bolted up. Filled trans and installed nifty billet plug for mechanical speedo hole. Wrestled with the exhaust for a few days but it's all in there now, although it will probably require some cutting and realigning once I start it up and discover how poorly the flanges seal to the headers. Got radiator/electric fan/shroud package in. Got all front-end accessories belted and bolted up. Got all coolant hoses installed. Got all the engine wiring routed and hooked up (alternator, coolant temp, oil pressure, fan power, starter, distributor leads). Carb and throttle linkage installed. Got fuel tank sump professionally welded then painted the tank and reinstalled. Got cast aluminum valve covers with pro welded tubes for clamp-on breathers installed.
    Major tasks ahead:
    Plumb fuel system from tank to mechanical pump to regulator to carb
    Stab distributor and cut custom plug wires (separate thread)
    Figure out the bird's nest of wiring related to OE air conditioning. I removed all that mass in favor of simplified fiberglass heat-only box but still have to procure and install a blower resistor (separate thread)
    Wire in T56 reverse light switch and reverse lockout (separate thread)
    Adapt pressure side of post-1980 power steering pump (metric o-ring) to OEM gearbox (inverted flare)
    Wire fan through relay to be always-on when engine is running
    Mount battery. OEM location was all ate up from years of spillage. I have a secondhand ICT Billet battery tray but haven't messed with it yet
    After I get all that done I can bolt up the hood, nose, and chin spoiler then move inside the cab...
    largestar likes this.
