Neutralize Salt
Discussion in 'The BS Topic' started by li0nhart123, May 23, 2010.
  1. Twisted_Metal
    26,219
    584
    Once.. Or twice. :screwup:
  2. docnascar
    docnascar Veteran Member
    2,552
    Feb 25, 2002
    Maryland
    A. Don't drive during the winter season until after it has rained a few time. You probably do this for the Camaro.
    B. Lots of water to wash it off. Spray. Goto a car wash that has the under carriage sprayers. They are not perfect but they help.
  3. rscamaro73
    rscamaro73 Administrator Staff Member
    X 2 That's what I do about once a month to the vehicles once they start salting the roads during the winter.
  4. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
    ^ +1 - defintely wash underneath more often; I spend half my time at the carwash hosing off the underside.
    Check to be sure that the drain holes are clear in the bottom of the doors & body panels. It doesn't take much to block them & the accumulation of salt & other debris will hold moisture there.
  5. speedyrev
    speedyrev Veteran Member
    2,165
    Jul 30, 2003
    Jackson, MS
  6. warped
    Water is the easiest. You might also look into this electronic rust preventative. The TV car shows were hawking it about 2 years ago, but $$
    http://counteractrust.com
  7. jroach
    jroach Veteran Member
    1,284
    Apr 9, 2007
    petersburg MI
    take a pump sprayer and some 5-20 and coat it
    or just let it leak.
  8. Todd80Z28
    11,168
    97
    Jun 11, 2002
    Northern VA
    Dilution is the solution!:)
    IIRC, the chlorine acts as a catalyst in the electron movements of the metal atoms, making them move more easily. That, in turn, increases the likelihood that the metal will bond with any dissolved oxygen in the water (or what's in the air), resulting in the metal oxide = rust.
    Washing away the chlorine source is really the best way to get rid of the problem. Cl(-), in general, is a VERY reactive element, so neutralizing its effects is tough to do.
    Or something like that.:screwup: You could say I'm... rusty.:)
    P.S. Acids have low pH, Alkalines have high pH.
  9. 79camaro2001
    4,765
    May 4, 2003
    Monroeville, PA
    Sounds like a small pressure washer is worth the investment when I move to the north.
  10. rscamaro73
    geek....lol.
