Need help choosing welder
Discussion in 'Garages, Workshops & Tools' started by allstar12316, Apr 29, 2013.
  1. allstar12316
    allstar12316 Veteran Member
    224
    Dec 6, 2011
    Manalapan, Nj
    I can either buy the hobart handler 140 for 500 new. Or get a lincoln sp 135 plus with cart around 275 used. Which should I steer to?
  2. John Wright
    13,976
    49
    Aug 9, 2002
    Rustburg, Va
    Based upon the fact that I can't see or try out the used welder, I say go on your gut, red and blue both make decent equipment....you'll have to decide whether to atke a chance on the used welder or not. If it welds good, it doesn't matter if it's used or not.
  3. allstar12316
    224
    Dec 6, 2011
    Manalapan, Nj
    The only reason I'm leaning toward the hobart 140 is it's new an has warrenty. But the lincoln has continuous voltage....
  4. John Wright
    13,976
    49
    Aug 9, 2002
    Rustburg, Va
    Just so you know....Both machines are CV(constant voltage) machines.
    edit for clarification*
    CV = constant voltage, the machine varies the amperage to maintain a constant voltage
    CC = constant current, the machine varies the voltage to maintain a constant amperage
  5. allstar12316
    224
    Dec 6, 2011
    Manalapan, Nj
    Online it is saying the hobart has a 5 tapp voltage controll
  6. 5spd540
    12,339
    10
    Sep 19, 2009
    Guyton, GA
    I have a hobart 140 and a miller 130 and the hobart welds better
  7. Krator
    Krator Veteran Member
    381
    Apr 24, 2013
    My buddy and I were looking around for a wire welder. Turned out Canadian Tire had one on sale almost 50% off. It was a small lincolne 220 unit 40 amp. We could not find a 110 unit for that price that would do as good a job. We tried. It pays to keep an eye out. I think it was the 480 model. It runs great can use flux core wire or run can with mig wire. Keep an eye out. SOmetimes when your not looking is the time you will find it.
    If you want welder reviews this site has almost anything you will come across.
    http://www.weldingtipsandtricks.com
    Look for the review section on the left side.
  8. John Wright
    13,976
    49
    Aug 9, 2002
    Rustburg, Va
    Oh you are talking about the user settings...yes, the Hobart has a few voltage selections to choose from....I don't remember if the lincoln has infinite voltage controls or not. I'm certain both have infinite wire feed controls.
  9. allstar12316
    224
    Dec 6, 2011
    Manalapan, Nj
    The Lincoln does hve both controls infanite. But is it worth taking a chance on the used machine? Or should I stick with the new hobart and stay with the warrenty
  10. John Wright
    13,976
    49
    Aug 9, 2002
    Rustburg, Va
    it's your money.....do as you see fit....LOL
    Have you seen or welded with the used machine? I'd make my decision based upon knowing how the used one welds before laying out any cash. Take some scrap material over to where the used welder is located and ask the seller to let you take it for a test drive.
