Need help and FAST!!!! 92 gmc 5.0L
Discussion in 'Troubleshooting & Diagnosis' started by bigblock665, Dec 10, 2010.
  1. bigblock665
    bigblock665 Veteran Member
    1,053
    Apr 7, 2009
    NY
    1992 1500 gmc 305 TPI... The engine does not idle for s**t!!! The idle fluctuates up and down while in park and stalls the second its in drive... I replaced fuel filter/pump. And still no better. I unhooked the coolant temp sensor on top of the intake and the fluctuating idle starts to go away but still stalls the second the truck is put in gear... I put in a new sensor and still no help, Still i have to unplug the sensor just to get the truck to stay running. Any idea's??? I need to get this done asap and cannot find help elsewhere!!!
    thanx
    joe
  2. bigblock665
    1,053
    Apr 7, 2009
    NY
    Im sorry i mean its a 305 "tbi" throttle body ..
  3. bigblock665
    1,053
    Apr 7, 2009
    NY
  4. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    Check the intake to TBI gasket. Sounds like yours has a small piece missing. This was a common problem with the fleet I worked on back in the 90's. Still never determined the cause for sure but suspected a faulty gasket, the factory gasket always blew out in the same spot and the replacement did not.
  5. Knuckle Dragger
    Knuckle Dragger Administrator Staff Member Lifetime Gold Member
    13,703
    672
    Nov 2, 2002
    Waddell AZ
    EGR stuck patialy open? I've seen that a lot.
  6. GoldenOne7710
    GoldenOne7710 Irrelevant Member Lifetime Gold Member
    4,508
    281
    Jun 23, 2004
    Athens, GA
    Also check your PCV tube. Follow the tube from the PCV valve to the TB. There's a 90* rubber elbow right where it turns into the front of the TB. Make sure that rubber elbow hasn't melted and collapsed. Most of the time when they melt....it melts a hole in the inside bend of that elbow......causing a serious vacuum leak that can cause the symptoms you describe.
  7. quadriderkyle
    quadriderkyle Member
    85
    Jan 4, 2010
    davenport iowa
    if those ideas dont work you could look at the throttle position sensor. my dads 95 tbi350 had that go bad, I dont remember exactly how it was acting as it was a while ago and not my truck but it is something to look at.
  8. Kamikaze
    =2^ on the EGR Valve and Gaskets.
    Pretty common on TBI GM vehicles
  9. bigblock665
    1,053
    Apr 7, 2009
    NY
    So your talking about the gasket between the throttle body and intake manifold?
  10. bigblock665
    1,053
    Apr 7, 2009
    NY
    someone has put a straight line on that, no elbow.
