Need educated guesses
Discussion in 'High Performance Modifications' started by biker, Oct 5, 2017.
  1. biker
    biker Veteran Member
    Looking for estimates as to what my cranking compression test readings should be.
    Calculated SCR is 10.01:1. Engine is small block 383. Cam is hydraulic roller .530/.545 lift, duration @.050 is 233/241 lobe separation is 110 degrees. 1.5 rocker arms. Performer RPM intake, 195 runner ATK heads with 2.02 intake valve. Quadrajet held wide open while cranking, engine warm.
    Considering the cam timing, intake and heads, I'm thinking there is not a great deal of intake velocity at cranking speed, especially with gear reduction starter.
    Closest guess wins the prize. Thanks guys.
    Brent.
  2. Bandit723
    Bandit723 Veteran Member
    2,260
    262
    Oct 1, 2016
    Waupaca WI
    I'm in 180 to 190....
  3. tom3
    tom3 Veteran Member
    10,761
    77
    Aug 1, 1999
    ohio
    Quite a bit of duration @ 110 degrees on a small block, but extra cubes there too. I'm a bit lower, 175 give or take 2 psi. Chicken Dinner?
  4. G72Zed
    G72Zed Veteran Member
    409
    28
    Sep 8, 2015
    What type of rings, specs ?
  5. biker
    Speed Pro hypereutectic pistons that came as part of my Eagle stroker kit with forged crank. Rings are 2.0mm, 1.5mm, 4.0mm.
  6. jimrr
    jimrr Veteran Member
    937
    173
    Jun 12, 2016
    sarasota
    157.89654732
  7. biker
    Well, Bandit is right in the ballpark, but Tom nailed it. 177 by my guage. I was asking because I see guys posting some high readings, but those must be some tamer camshafts. I've been applying some tame cam logic to my tuning, but as Tom said, pretty long duration to expect great idle manners. Idle seems happiest at about 1000, but I am a bit lean on idle mixtures despite opening up the QJet idle circuits.
    Thanks guys, good to know my cranking pressure is about where it should be.
    Tom, if you find yourself in Northern Ontario, chicken dinner is on me.
    Brent.
  8. biker
    Great. A science geek.
  9. G72Zed
    409
    28
    Sep 8, 2015
    I say around 185, and +12-15 psi more if it was a 2 piece total seal top ring.
  10. 77 cruiser
    77 cruiser Veteran Member
    447
    12
    Nov 17, 2006
    Frostbite Falls MN
    How much vac. at idle?​
