My Daily Driver won't start...
Discussion in 'Troubleshooting & Diagnosis' started by Cougar125, Feb 21, 2009.
  1. Cougar125
    Cougar125 Veteran Member Lifetime Gold Member
    2,698
    Aug 21, 2005
    Whidbey Island, WA
    Ok. My daily driver is a 77 chevy p/u with a 5.7lt V8 350 sbc.
    You get in turn the key. Accessories turn on. Turn the key to start and there is nothing.
    I've had the battery and starter both bench tested. They are fine. When I reinstalled them, I checked my grounds from the block to the battery and from the battery to the body. They were both clean and good.
    I tried getting the starter to kick over on its own by shorting the hot to the other post (the one with the little wire on it) and it wouldn't do anything (I'm thinking solenoid may be faulty?) After that, I used alligator clips to jump the hot to the starter motor. The starter spun up like it was supposed to, but when I tried it again it wouldn't do anything.
    If somebody could get me pointed in the right direction, it'd be helpful. I have to have the truck back up and running by thursday because I'm moving to San Diego next Monday.
    Thanks guys.
  2. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    If you are getting 12 volts from the igniton wire, and you are getting 12 volts from the battery wires and your battery is fine. Then I would say it's a faulty starter that's working when it wants to.
    You cleaned the surface where the starter mounts to the block?
  3. Cougar125
    2,698
    Aug 21, 2005
    Whidbey Island, WA
    I'll pull it again and buff the mounting surfaces.
    I got off the phone with a friend of mine. He says
    Well, seeing as how I don't have the money to go buy a new starter, I want to see if there is something else I might try and look at before throwing money into this pit.
  4. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    I am leaning toward a bad starter also if all of your wires are giving the correct voltage.
    You could take it apart and check contacts and such, but Autozone sells a good starter for a decent price. Less then $50 I think and lifetime warranty.
  5. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    Just checked, part number DL3510S for $44.99 with a core swap.
    That's the one I use in the camaro and it's been good.
    Alternator on the other hand keep crapping out on me though.
  6. Knuckle Dragger
    Knuckle Dragger Administrator Staff Member Lifetime Gold Member
    13,468
    541
    Nov 2, 2002
    Waddell AZ
    Pull the starter and take the solenoid off. Make sure there is nothing built up between the solenoid and plunger (I've seen some sort of white powder corrosion more than once). If you can, take the solenoid apart and clean the contacts inside. Crap builds up and you get this issue. Cleaning it all up may get you back on the road cheap.
    You used to be able to buy a solenoid separate for about $10 at the chain parts stores. Back in the day they always came separate.
  7. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    Most chain store don't even carry just the solenoid. But i think NAPA does.
  8. Knuckle Dragger
    13,468
    541
    Nov 2, 2002
    Waddell AZ
    That makes me feel old.
    I'll bet a good cleaning will take care of the issues.
  9. gordonquixote
    3,016
    Jul 18, 2006
    Tallahassee, FL
    Do you hear the solenoid 'click' when you turn the key?
  10. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    I remember them doing this back in high school cause i rebuilt a starter, but you had to order it. Most chains will order it, but i was just saying they don't carry them on the shelf.
