My 79Z bodywork
Discussion in 'Project Progress' started by earnhardtgm3, Aug 21, 2008.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    Shifter with the Black Hurst Knob
  2. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    Clock converted to Oil Press gauge from Gauge Marks (Daniel).
  3. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    Time to get some more stuff done now as it gets warmer. Got to get the quick release steering mounted amoung some other things.
    New upper and lower A Arms
    All new steering linkage rebuild kit
    Low profile Cal-Tracs for the rear along with new bushings for the leaf springs
    New 100 amp alternator
    New Morris seat belts
    The FiTech unit is working flawlessly and really like how easy it starts.
    Had the motor dynoed by my builder of motor and made 16HP and 20LBS more than with the Holley 770 Street Avenger on it. 503 HP 513 Ft Lbs TQ.
    Blu-By-U 79Z likes this.
  4. 80sz
    80sz Veteran Member
    2,701
    268
    Feb 2, 2014
    Buffalo,n.y.
    Good stuff . Atomization is key with the new fi carbs. Its hard to beat a fine mist of gas for a explosion
  5. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    Had some minor set backs, so now the car is off to get some things installed.
    New front/rear drilled/slotted rotors along with new hawk pads.
    Got my roll bar and G Bars in also today from PTFB.
    Pics will follow at a later date.
    Also got my AC system yet to be installed from: Original Air
    https://originalair.com/77-81-camaro-134a-rotary-compressor-upgrade-kit
  6. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
  7. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    More upgrades:
    Rear Gear Cover
    Chevy 8.5" 10 Bolt Rear End Girdle - Low Profile
    TA_1807Ahttp://www.taperformance.com/proddetail.asp?prod=TA%5F1807A
    Cal Tracs installed--using the low profile design Model 2401
    http://www.calvertracing.com/store/caltracs-2401-low-profile-1-hole-p-143.html
    Added removable steering wheel with quick release:
    NRG SRK-170H Steering Wheel Short Hub Adapter
    http://www.getnrg.com/index.php?route=product/product&path=172&product_id=685
    Quick Release used:
    NRG Innovations SRK-250BK Quick Release Kit (Black/Black Ring with Finger Grooves)
    http://www.getnrg.com/index.php?route=product/product&product_id=919&search=SRK-250BK
  8. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
  9. earnhardtgm3
    1,517
    16
    Dec 18, 2007
    Camaro Country,GA
    Bought a NRG Lock Assy for steering wheel, mostly a theft deterrent. Did have my lock key modified by local locksmith though for further theft prevention.
