My 79Z bodywork
Discussion in 'Project Progress' started by earnhardtgm3, Aug 21, 2008.
  1. camolaa_69
    camolaa_69 Veteran Member
    107
    Oct 12, 2010
    Australia
    Beautiful car. The paint work came out very nicely. You have a fine car. Enjoy the moments with the car, the car will treat you well.
  2. earnhardtgm3
    earnhardtgm3 Veteran Member
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    Thanks for the comment.
    Next will be installing a Hurst Quarter Stick Shifter made for the console,
  3. earnhardtgm3
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    Engraved aluminum HURST LOGO shifter shift knob
    Found this shifter ball to use:
  4. earnhardtgm3
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    FITech is up and running..........Starts on the first turn of key,and runs like never before with the Holley 770 Street Avenger on it. Still got some tweaking to do on it. Like find a carb spacer or a different fitting for the drop down air cleaner to fit. I have a slight off idle stumble,but I know I can tune it some with the IAC adjustments.. I can really feel more power by the seat of the pants feel.. My motor guy wants to put on dyno and see the after effects of EFI vs the carb that was on it.
    Blu-By-U 79Z likes this.
  5. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,533
    14
    Feb 11, 2009
    Kentucky
    Thanks for the update man. Im eager to hear more!
  6. earnhardtgm3
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    Hurst Quarter Shifter installed in console. Shifts and fell real nice.
  7. hot72rod
    Please post the dyno results.
    Dkmurdock likes this.
  8. earnhardtgm3
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    Sure will after it gets some fine tuning done.Almost there.
    Swapping out the speedometer gears now to get closer to correct MPH on speedometer-right now I'm 10MPH off.
  9. 80sz
    80sz Veteran Member
    2,626
    252
    Feb 2, 2014
    Buffalo,n.y.
    Shifter looks good.
  10. earnhardtgm3
    1,509
    16
    Dec 18, 2007
    Camaro Country,GA
    Almost done with the EFI set up and console shifter is done. New speedometer gears are installed,need to test the MPH against the RPM readings. Will use a MPH app on IPhone for accuracy. As it is accurate for my other vehicles.
    Next will be adding a removable steering wheel.
    Got the short hub adapter and quick release on order. Got to pick a steering wheel to fit the Camaro. Any ideas?
    Here is the short hub adapter:
    http://www.getnrg.com/index.php?route=product/product&path=172&product_id=685
    Here is the quick release:
    http://www.getnrg.com/index.php?route=product/product&path=69_25&product_id=919
