My 74 rear end what do I have
Discussion in '1974 Specific' started by Camaro_madness, Apr 8, 2017.
What exactly do I have first time for this
  1. Idk
    0 vote(s)
    0.0%
  2. The differential
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Camaro_madness
    Camaro_madness New Member
    Apr 8, 2017
  2. Gary S
    21,263
    359
    It looks like some kind of spool with no differential action. If so, it is bad for use on the street.
    A GM rear end should look like this inside.
  3. Camaro_madness
    Apr 8, 2017
    Yeah I have no differential. I'm trying to figure out how do I get the axles out if I have no c clips.
  4. Jeep43
    Jeep43 Veteran Member
    1,004
    9
    Mar 30, 1999
    Connecticut
    Must have C clip eliminators. Pull the drums off and look behind the axle flange. There should be an aftermarket bearing retainer bolted to the backing plate/housing flange.
    twozs likes this.
  5. Camaro_madness
    Apr 8, 2017
    Yes I figured it out well I can't change out the differential now so I'm gonna drive it until I tear it up.
  6. CamaroGP
    CamaroGP Veteran Member Gold Member
    691
    89
    Nov 10, 2012
    Summerfield, Florida
    You can still put a posi or one wheel in there with c-clip eliminators. Eliminators do just what the name implies, eliminates the c-clips. All the other guts in there will work just fine. Just make sure if you have after market axles that whatever new diff you get matches the splines.
  7. Camaro_madness
    Apr 8, 2017
    Ok cool. I'm gonna spin tires with the spool for a while with the ls 5.3
