My 70 RS/SS 350
Discussion in 'Project Progress' started by John Wright, Feb 19, 2008.
  1. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
  2. fastrun72
    fastrun72 Member
    33
    Dec 24, 2008
    Petaluma,California
    Hey John where did you get your led light kits from. ive been wanting to do this upgrade for sometime now...
  3. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
  4. Boerst73
    Boerst73 Veteran Member
    124
    Jan 8, 2013
    Seymour, WI
  5. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    Added hood pins since the intercooler takes up the space where the factory latch resides.
    green 1977 likes this.
  6. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    The Megasquirt ms3 is here.
  7. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    I ordered a Summit Universal fit intercooler and it came in the other day. I test fit it lastnight and there is a glimmer of hope that I may be able to bolt my factory hood latch back on. ::fingers crossed:: I feel a bit better knowing the factory latch would catch the hood if those hood pins should fail for some reason.
    It is a little bit shorter in depth and length than the previous I/C that I bought from VS Racing. The VS Racing was too long and the inlet/outlet was behind the headlights on both sides. With this one, I will be able to route the intercooler tubing out beside the radiator on each side(between the head lights and the radiator).
  8. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    Summit intercooler mounted
  9. hoppin5478
    537
    84
    Jul 20, 2015
    Tucson, AZ
    Looking good, now the real fun begins plumbing it. It took some time and creativity to get the tubing in mine and in a good spot. I'm also anxious to see how you like the MS3 and watch it all come together. Love the build!
    John Wright likes this.
  10. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    Trunk battery box to make room for power adder under the hood.
    Cut off switch, just in case.....
    Ford starter solenoid, just be cause of long runs of large diameter cable with lots of amps makes me nervous.
