My 70 is a non tilt column....found a 79 tilt...can I make it work?
Discussion in '1970 - 1973 Specific' started by Tpichevy, Feb 3, 2018.
  1. Tpichevy
    Tpichevy Veteran Member
    449
    14
    Jun 21, 2016
    Boise id
    Have wanted a tilt steering column for my 70 Camaro 4spd and found a nice tilt from a 79.... Looks like after reading up some that there are changes. But can it be made to work or not worth the hassle?
  2. Zspoiler
    Zspoiler Veteran Member
    2,845
    178
    May 6, 2012
    Federal Way, Washington
    It should fit since they are basically the same car
  3. dkcamaro
    dkcamaro Veteran Member Lifetime Gold Member
    It will work, But 79 has a double D shaft ( where in connects the column to the steering shaft). You will need the shaft from the column to the steering box from the 79 also
  4. Twisted_Metal
    26,218
    582
    ^ That's the physical problem with the swap.
    It will take some reengineering to swap compatible parts for the steering shaft.
    There may have been some wiring harness changes also.
  5. 71RS6SPD
    71RS6SPD Veteran Member
    203
    Nov 14, 2016
    The plug is also different but not hard to swap your existing one in
