My 1972 Chevy Camaro SS Restoration Project
Discussion in 'Project Progress' started by Tankdawg971, Dec 18, 2017.
  1. Tankdawg971
    Tankdawg971 New Member
    Dec 18, 2017
    Thank you...
  2. Tankdawg971
    Dec 18, 2017
    wow that is some power
  3. jkhall
    jkhall Member
    50
    Dec 5, 2017
    No lift motorsports has a special going until new years: LQ4 with stage 1-4 cam installed 2600 shipped. SO I had them also put the oil pan for the 2nd gen Camaro on it for another $250. Then I bit the bullet and said if they are putting a cam and dual valve springs on it, might as well do a full reseal of the motor with Ls7 lifters and ls9 head gaskets. I figured screw it, I will get the 4L60e with an upgraded corvette servo to solve the 1st to 2nd gear issue and added a monster torque converter 2300-2500 stall. all out the door, shipped to a local terminal it's $4480. I could not resist. it comes with stand-alone wiring harness and a programmed computer. all in all, not a bad deal. I am debating yanking the heads off immediately and having them ported by a local shop here and replacing the manifold with a Fast LSX-RT and 102mm TB. thats about 2k. I do want to stay with the 243 heads.. no need to go rectangular ports unless I plan on spending a lot of time above 6k RPMs... and I dont.
