My 1971 LS Swapped Pro-Touring Project
Discussion in 'Project Progress' started by 1971CamaroGuy, May 15, 2012.
  1. 1971CamaroGuy
    1971CamaroGuy Veteran Member
    3,460
    82
    Oct 31, 2004
    Arkansas
    the sanden AC compressor for my vintage air system took up that spot
  2. thesalboy
    thesalboy Veteran Member
    107
    15
    Mar 25, 2017
    Los Angeles, CA
    Ahh, of course. Will face the same issue on my LS1 swap. You go with Sanden SD5 or SD7? Are those Vintage Air brackets? I'm thinking of going with Holley's A/C bracket and making the rest of stock work. Will follow your lead on running A/C hoses above the kick panel, and mounting ECU, and, and, and... Thanks!!!
  3. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
    no prob at all
    I can't remember which compressor, it's the larger one they supplied with the kit. Originally had the vintage air supplied brackets in the beginning (they are just kwik performance brackets) but have since swapped to the Holley stuff in the later pictures.
  4. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
    Goodies are starting to come in, got the leafs and CPP brake kit today. The spindles are raw cast so i def will need to paint those
    2018-02-28 18.53.02.jpg 2018-02-28 18.53.13.jpg 2018-02-28 18.53.16.jpg 2018-02-28 18.53.24.jpg 2018-02-28 18.54.53.jpg 2018-02-28 18.55.10-2.jpg 2018-02-28 18.55.31.jpg 2018-02-28 18.55.59.jpg 2018-02-28 18.56.03.jpg
  5. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    982
    9
    Apr 27, 2010
    Verona, ITALY
    Looking good!
  6. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
  7. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
    Wheels and tires came in earlier!
  8. thesalboy
    107
    15
    Mar 25, 2017
    Los Angeles, CA
    NICE! Specs, especially backspace? You flatten rear seat belt hump?
  9. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
    Haven't put them on yet but don't forsee any issues based on the research I have done.
    They are Ridler 695's 18x8 4.5" BS for the front and 18x9.5" 5.5" BS on the rear
    tires are 235/40 on front and 275/35 for the rear
    I'll be putting them on in a few weeks
  10. 1971CamaroGuy
    3,460
    82
    Oct 31, 2004
    Arkansas
    Went ahead and got some teflon lined socket wrenches to put these on and wife is working late today so I might go ahead and do a test fit and out them on. Tires are roughly same height as my old one's but with a bigger rim. I had 245's all the way around but this time it's going to be 235 in the front and 275 in the back
    Just put one beside the old wheel to get an idea of the size
